ECUFlash accel enrichment table not really accel enrichment?
Well, I added these 4 tables...now what do I do with them? Basically, I want to decrease the amount of additional fuel that is dumped at throttle tip-in to help eliminate the black puff. I am running FIC 850cc injectors. I multiplied the "cold start enrichment table" values by .7 which worked out very well and was hoping the accel enrichment had something similar.
I have a problem and I wonder if this is the right table to use to fix it. Basically, whenever I move off from a complete stop, the AFR will go very lean to around 18.0 for a second or two before richening up again. This causes the car to stumble badly and can be quite a problem especially when I'm stuck on a slope
It only happens when I'm moving off from a complete stop...everywhere else is fine. Any idea?
Slo_crx1
Apr 3, 2008 03:57 AM
