Please help translate the log...
Old May 3, 2008 | 07:25 AM
asdfasdf128's Avatar
I recently had a TBE installed and figured I'd run a log & see whats going on...anyways attached to this are a few logs. Any help/words of advice would be nice. btw, I dont have a wideband yet.
File Type: zip
Old May 3, 2008 | 10:01 AM
ChuckP's Avatar
So did you go WOT in any of these logs?
Old May 3, 2008 | 11:09 AM
yep. I went to redline & then had to fumble w/ laptop to stop the log.
Old May 3, 2008 | 11:10 AM
nvm
Old May 3, 2008 | 03:48 PM
Old May 3, 2008 | 05:39 PM
nothere's Avatar
looking at one of the files... looks like you did not push the pedal to the carpet. TPS should read 100, not 53? maybe there is something wrong with the sensor calibration?
anyway it would be difficult to make any changes to your rom from looking at those logs. you need to see afr, timing, 2byte load, knock sum, rpm. I know your logs have some of those indicated but you really need those as a minimum.
What you are trying to do is find the condition of your motor in the worst case conditions. I like to do a log going up an incline, wot, from above 3000 rpm with the trunk full of tools.. To be really **** you might go from 2500 rpm but thats not some thing I do anyway. In your case, since you are just looking to see what is going on you prolly did it about right. Next time push the envelope a bit more.
good luck, be safe and get help.
jakgal04
Mar 28, 2016 08:16 AM
Dochka
Mar 17, 2011 03:46 AM
ms_logging
May 28, 2010 06:46 AM
kapolani
Feb 3, 2007 06:21 AM
jasonn
Oct 25, 2005 08:43 PM
