Rom ID
Old May 14, 2008 | 10:26 AM
jimn's Avatar
Rom ID
This may be a bit of a stupid question but on eculash my rom id is listed as: 98640014.
Is this the deffinately the rom id or is it just listed as this because that is the XML i attained that would read it?
I suppose what im trying to ascertain is. Do other xml files open my rom or is it specific and do i have the correct xml with all the available options?
Thanks in advance, Jamie
Old May 14, 2008 | 11:39 AM
R. Mutt's Avatar
It's more than likely you don't have the definition file and told it to inherit the evo VII base 98640014. I assume this since I don't know of anyone who has a definition file for the evo IV. Definition files for evo go from the VII up, since you can't reflash CP9A models at this time.
Did you use a cable purchased from evoscan.org to pull the rom?
Old May 14, 2008 | 11:49 AM
jimn's Avatar
Its a VII that i have now. I will change my sig..
I didnt inherit i dont think i just put that xml into ecuflash then read out my JDM VII rom.
I think i may have found the answer to my own question from searching> If the options are there and work i have the right deff..
My only next question is can i write a map from another car - 7 or 8 that has a different definition to my ECU safely?
Old May 14, 2008 | 01:27 PM
R. Mutt's Avatar
you can reflash to another map from a 7 safely not an 8 or 9
Old May 14, 2008 | 06:13 PM
sub7's Avatar
Hope to share a fair bit of my experience, dave's v5 rom for e8ra work on my e7jdm That's for cel, altmap and valet feature, but ntls is still down in my wish list. I won't suggest you reflash other car tuning into your own. But hey, my stock romid is 98640014!
Old May 14, 2008 | 09:26 PM
tephra's Avatar
but only because your car doesn't have a top clutch switch so NLTS can't work
sub7 - does your altmap work now?
Old May 15, 2008 | 12:23 AM
jimn's Avatar
TBH this is why i was asking the question. I want to install the tephra mod but my original ECU isnt listed.
I have changed all the values on 90550001 and can read all the options but i didnt dare flash yet until i knew it was safe..
Is this the E8 ra rom?
Also how do you wire in the switch for alternate maps?
Old May 15, 2008 | 01:20 AM
sub7's Avatar
You got mail
Jim,
If your E7jdm spec has autoics, altmap should work! Have been using dave's v5 over a month now without trouble (extra 2-3 knock)...
Old May 15, 2008 | 04:22 AM
jimn's Avatar
You got mail
Jim,
Autoics - Auto intercooler water spray..? Yes it has.
I have had to change alot of the fuel options aswell as the ignition and fuel maps.
Does this sound right?
I will try it tonight..!
Old May 15, 2008 | 04:34 AM
sub7's Avatar
Yeap, look out for your stock load cell. You should have 0-260 and the new v5 have 0-300 load. Make sure you copy the right load cell to your new rom
Old May 15, 2008 | 07:03 AM
jimn's Avatar
My car had been remapped already so i changed those.
Should i data log a couple of runs with the new rom or will ibe o.k just keeping an eye on the newly flashing knock light?
Old May 15, 2008 | 03:02 PM
burgers22's Avatar
Tephra's ROM will work fine.Get the xml in the thred https://www.evolutionm.net/forums/sh...d.php?t=343094 if you still need it. Any questions on this ROM ID give me a shout.
MB
Old May 15, 2008 | 03:37 PM
jimn's Avatar
MB
The XML on that thread isnt listed on tephras thread.. (or i cant see it)
I have changed the map on rom 90550001 so it is the same as my ****014 (cant remember the exact deff) Is that good enough?
I feel like i need to meet all you u.k. ecuflash boys so i can get the stupid little questions i have so i can get into the proper stuff.
EDIT: I just got it.. The deff you have shown me is a good version of the one i am using - this will give me stationary rev limits then if i want all the extra features of V5 i will be o.k using 90550001 on my ecu as long as i change/check all the values in the rom. ! :thubmsup:
richardjh
Sep 17, 2023 01:02 AM
TariqEvo
Dec 9, 2021 12:36 AM
paoloM
Jun 16, 2016 06:31 AM
Wanchai Panpron
Lancer Engine Management / Tuning Forums
Nov 30, 2015 06:46 AM
grim~
Dec 24, 2011 03:16 AM
