PID boost control code
Old May 21, 2008 | 11:15 PM
  #46
dudical26's Avatar
Originally Posted by tephra
definitely...
I am just having trouble at the moment because I am trying to simulate different P,I,D gains and their affect on the Output WGDC.
I was kinda hoping that 1 P,I,D would fit all, but I think its going to be a case of every car is different :\
I think you are right in saying each car is different. It matters a lot on turbo, what solenoid you use, if you have restrictor pills in, altitude, etc...
With that being said I think most people using stock turbo and a GM solenoid should be able to have pretty similar gain settings.
Old May 22, 2008 | 03:27 PM
  #47
dan l's Avatar
definitely...
1 PID would fit all, each user would have to tune to their car however.
Old May 23, 2008 | 08:03 AM
  #48
burgers22's Avatar
Originally Posted by mrfred
I hear quite a few people talking about having difficulty with the boost overshoot. Makes me wonder if a smaller pill at the tee is not the way to go. Can't say for sure though because razorlab seems to be able to make the restrictor pill method work very well, and I've never tried the restrictor pill method.
I think the best method is to make BDLE roughly the same as the boost you are actually getting during spool, and make WGDC about the same as that which you need to archive peak boost.
I do not support the idea that having WGDC at 100% will improve spool. This would only be true if the wastegate was opening during the spool period, and the BCS was not able to bleed enough air to stop this happening.
MB
Old May 23, 2008 | 09:11 AM
  #49
mrfred's Avatar
MB
The question is how to know for sure that the WG is staying shut until getting close to target boost.
Old May 23, 2008 | 10:03 AM
  #50
jcsbanks's Avatar
When I've played with handheld pumps and actuators before they only move impressively close to their rating with little in the way of "wastegate creep".
mrb00st
E85 / Ethanol
189
Oct 11, 2024 04:59 PM
dr_latino999
Nov 10, 2016 01:15 PM
kiddsm95
Feb 18, 2016 06:01 AM
silver_evo
Jun 25, 2010 11:31 AM
jfitzpat
Jan 17, 2007 09:32 PM
