Tuning for improved highway mileage
Old May 30, 2008 | 09:45 AM
spdracerut's Avatar
Originally Posted by TouringBubble
There is a sometimes un-defined table that actually adds timing advance in those cruise areas already ... it's defined for the 94170015 ROM already and I know JB was playing with it on the IX ROM. I would think the best approach from your angle would be to define that table and make your advance adjustments there as I believe there are conditions in place for using or not using that map ... knock, etc.
I was just wondering about that.... I saw timing hit 41 degrees and the highest the map goes to is 38. Good to know. Now I just need to define this new table.
Old May 30, 2008 | 10:06 AM
rallykid's Avatar
where can I find those cross over maps and how to change them? Is this written out somewhere?
Old May 30, 2008 | 10:20 AM
inco9nito99's Avatar
Search "Mileage" its a thread posted in the ECUFlash forums..HUGE thread.
Old May 30, 2008 | 11:43 AM
GEARS's Avatar
Good thread, I'm always looking to improve mpg
I think that it would be useful if we dial in everyone's comparison at a known speed or engine rpm.
It might be of help to include any of the critical mods and or parts that will effect fuel economy and some notes, so we can make comments about the state of tune or anything else worth mentioning. Please be honest with your mpg too.
Something like this....
I get 30mpg when I'm driving at 3000rpm but only 26mpg when driving at 3500rpm.
CAR = 05 MR w/ 6speed
TURBO = stock
IC & PIPING = stock
FUEL PUMP = stock
FUEL INJECTORS = stock
EXHAUST = stock
ADDITIONAL MODS = ECUFLASH, K&N air filter
NOTES = not all that happy with my low fuel trims, 108-119's
Old May 30, 2008 | 02:54 PM
C6C6CH3vo's Avatar
Anyone know which Open Loop Load or Throttle table controls the egr solenoid?
Running egr in open loop might significantly cut fuel consumption if leaned just before combustion goes goofy. Several degrees of spark advance will help the miss too
Old May 30, 2008 | 04:04 PM
nothere's Avatar
https://www.evolutionm.net/forums/sh...=300576&page=2
your best bet is to read the whole enchilada.
As I said, it can put you in open loop full time and from there you can choose the afr you want. Once you have the open loop part done you go into the fuel map and change those low load cells.
Old May 30, 2008 | 04:33 PM
nonschlont's Avatar
I would like to try the open loop mod, but still rinning the stock cat, so I tried this...
I just added 3* to my HOI maps from 2000-6000 in the 30 - 50 as well as add a few * all the way up to 120 load, not every cell, just to smooth things out a bit, and logged this morning. Cant say that I felt any difference, as I didnt really hit anything past 34%tps but I only saw 1 count of knock randomly... (4 logs)
Good idea!
SeanM505
Jun 18, 2015 10:22 PM
killerpenguin21
13
Apr 7, 2012 04:49 PM
RAC3ME
Dec 15, 2010 08:41 PM
hyeteck
Nov 1, 2010 09:33 PM
oak2207
10
Jan 28, 2008 10:20 AM
