Buschur intake pipe
Old Jun 1, 2008 | 12:49 PM
RedLanEVO's Avatar
Ok, I really appreciate it. Will do tonight.
Old Jun 1, 2008 | 12:52 PM
DocMortal's Avatar
I heard that the intake pipe needs 2 bends , I also had trouble with the buschur pipe,I got it replaced and the idle is 100% better. I replaced it with one from tuning technologies and has the standard 2 bends in it before the turbo I heard to keep the air straight?
I love Buschur Parts but in my experience there intake pipe didnt work well in my car .
Old Jun 1, 2008 | 01:05 PM
RedLanEVO's Avatar
^^really.
Old Jun 2, 2008 | 07:03 AM
Kracka's Avatar
I think you need a real tune by someone who actually knows what they are doing. Take your car to Shane at DB in Rogers, MN and I'm sure you'll walk away thrilled with how your car drives. Locally, both Scheides and I have the Buschur intake pipe with zero issues.
RedLanEVO's Avatar
Here are my logs. I did these with my changed values in the maf scaling.
There are 2 cruise logs and 1 idle log.
File Type: zip
Old Jun 2, 2008 | 07:11 AM
RedLanEVO's Avatar
You guys also have different setups than I do. When you installed your Buschur pipe without a tune, did it ever not want to start?
Old Jun 2, 2008 | 07:15 AM
RedLanEVO's Avatar
It's not only that I don't want to take it to a tuner...I want to learn myself. That is why I read and read and research plus this is what these forums are for.
Old Jun 2, 2008 | 07:21 AM
scheides's Avatar
EvoM Moderator
I don't think your setup is *that* much different than either of ours, it's just an evo w/ a stock frame turbo. My 05 started right up on the stock tune with that intake on, that was with buschur TBE, deluxe fmic, and the intake. Shane tuned it w/ some maf scaling and even with the hks 280's I have in the car now it idles like a dream. I've done plenty of other mods too, IX turbo, ported hotside stuff, ss o2 housing, ported intake mani/65mm tbody, aquamist alky injection, clutch, lightweight flywheel.....what makes your setup so different?
You just seem to start a LOT of new threads revolving around the same issues...
Old Jun 2, 2008 | 07:26 AM
RedLanEVO's Avatar
Well, mine started up, idled until it warmed up then died and wouldn't start even though the injectors are scaled perfectly. I've got the car to run with the Buschur now but just needs fine tuning.
Also, I have an idea of how to scale and have been doing so since a month or 2 ago. It just seems so that this Buschur part might not be suitable for my use.
Old Jun 2, 2008 | 07:28 AM
scheides's Avatar
EvoM Moderator
You didn't answer my question, what makes your setup so different than mine? Are you running some crazy huge cams or something? Which orientation do you have the pipe installed, with the short end into the turbo or the mas? This can yield different results too!
Old Jun 2, 2008 | 07:32 AM
fugiwara's Avatar
If no one can help me on this, I guess I'll buy an ETS intake and see if it makes a difference. This Buschur hard-pipe is really giving me a headache.
Why do you must stick with a hard pipe? why can't you just put back the stock one if it runs Perfectly fine? I used to think that pipe will make a difference, but realized don't waste my time and money on part like that. If the buschur doesn't work just stick with the stock one. Aftermarket hardpipe is known for problems for stock MAF. That little pipe will not yield you significant hp gain
Old Jun 2, 2008 | 07:36 AM
scheides's Avatar
EvoM Moderator
+1, put the stocker back on, I'll buy your buschur one from you; I got $50 right here for ya
Old Jun 2, 2008 | 07:51 AM
RedLanEVO's Avatar
Well, I have GSC S2's. They're not that huge of cams. I have the short end to the turbo.
Old Jun 2, 2008 | 07:52 AM
RedLanEVO's Avatar
No, sorry, I guess you don't get it. I want to do this myself.
....and I need this to work because I will have my HTA37r this Wed.
Have you ever heard of the stock rubber pipe fitting onto a 4" compressor inlet?
Old Jun 2, 2008 | 07:54 AM
RedLanEVO's Avatar
If you buy Evotime's AEM intake, I'll trade ya
