updated xml for 99860002
Old Jun 1, 2008 | 09:59 AM
mrfred's Avatar
Hey Folks,
I've been doing some work for a guy who owns an Evo 7 with ROM ID 99860002. As part of the work, I updated xml file for this ROM. I started with some 99860002 xml files I found here and on OpenECU.org. I fixed quite a few errors in the xml files, and I was able to add some additional tables, so this should be a pretty good step forward for 99860002 Evo 7 owners. This definition may also work perfectly for 90550001 owners. Try changing the header info in the 99860002 xml to match the 90550001 info.
The 99860002.xml and evo7base.xml file are attached. Both are neede for proper display of the tables.
File Type: zip
File Type: zip
Old Jun 1, 2008 | 10:51 AM
sub7's Avatar
Thanks Fred, I can test them for you.
I use your evo7base xml with my existing 90550001 or 98640014 xml (ecuflash 1.34 or later), the timing/afr scaling is ok. If I change 99860002 header info to 98640014 or 90550001, timing/afr scaling is screwed. Then I realise 99860002 x and y axis address are different from 98640014/9055001. These are just hi-fuel and ignit examples I spot the differences... there maybe more
99860002
Hi-fuel (35bd)
x - 5690
y - 5668
Hi-igt (3b85)
x - 56ee
y - 56be
98640014/90550001
Hi-fuel (35bd)
x - 4fdc
y - 4fb4
Hi-igt (3b85)
x - 503a
y - 500a
Old Jun 1, 2008 | 11:16 AM
mrfred's Avatar
I use evo7base_20080601 xml with my existing 90550001 or 98640014, the scaling for timing/afr screwed up. Are those xml specifically meant for 99860002 only?
Yes, it probably only works with the 99860002.xml file I posted.
Old Jun 1, 2008 | 11:28 AM
sub7's Avatar
Sorry, I just updated my old post.
Old Jun 1, 2008 | 12:10 PM
mrfred's Avatar
In that case, the evo7base.xml wouldn't work with those ROM xmls.
Dow Jhob
Aug 4, 2023 06:35 AM
ug_orf
Feb 19, 2016 09:26 AM
Donnyevo7
Jan 3, 2016 08:01 PM
TJung
Apr 28, 2012 10:41 PM
Malmoe_Sweden
Feb 13, 2008 12:57 PM
