Let's see your lean spool disable Fuel Maps
An interesting thing is that you are not modifying the map area where load is less than 140, not even on the RPM ranges from 2500 to 7000. On this area there will be an impact in AFR due to changes in lean spool, any issues with that? Have you seen any changes in your wideband? Looks like the number difference between lean spool enable and disable is about 1 point.
lean spool is a definate must, i did it cause everyone said it was more consistent and you really dont understand that untill your trying to tune over the course of a few days and it doesnt change from day to day like crazy
i herd that the new version of ecuflash is gunna have that as a feature (disable lean spool)
By looking at the stock fuel maps of an EVO 8 it looks like lean spool does not happen at the same RPM at all loads. It is close to 2500 rpm for higer loads (higher than 160) and it apperas to occurs at higher rpms at lower loads (70~160). It doesnt look like its doing anything for a really low loads (less than 70). In addition the transition point in the low octane map appear to be about 50 rpm sooner. Have anyone notice this. It is clearly seen by looking at the stock fuel maps.
stock the ECU has "lean spool enabled" this means that the ECU will lean out the fuel map by 'about' 1 full AFR point.
most tuners/people "disable lean spool" to remove this affect, and then manually lean their fuel map out.
lean spool has a lot of "unknowns" in its operation - so rather than putting up with random things happening _we_ turn it off
I want to try disabling lean spool on my car and I do not want to log the car pig rich. Adding 1 full AFR point should get me close and then I can fine tune it from their. Correct?
richardjh
Jun 18, 2011 10:16 AM
