Idle troubles
Old Jun 8, 2008 | 03:57 AM
epson1's Avatar
Idle troubles
Right now the car has 1000cc injectors and BC 272's. I've messed with some of the idle tables in ecu flash but they haven't really fixed anything.
It's not that the idle is too low but my car wants to idle high. like 900-1200 high. with the new cams the car wants to "lobe" sometimes but it comes right back up.
Is there anyway i can drop the idle down to about 800 with out messing with the set screw on the TB?
Old Jun 8, 2008 | 11:11 AM
RedLanEVO's Avatar
Did you just install the injectors with the cams? If so, you will need to rescale the injectors. Also, if it idles between 900-1200, check for vacuum leaks.
Old Jun 8, 2008 | 11:49 AM
epson1's Avatar
The injectors have already been rescaled to 914cc's. Also there are no vacuum leaks
Old Jun 8, 2008 | 12:36 PM
PeteyTurbo's Avatar
Did you install the cams prior or at the same time?? Try playing with timing in that area and dont forget sometimes the car will drop rpm at idle and hit a higher load to get the rpms back up thus mabye coming out of your idle timing settings..
Old Jun 8, 2008 | 01:30 PM
RazorLab's Avatar
914 seems a bit high. Which 1000cc injectors? What are your fuel trims telling you?
Old Jun 8, 2008 | 01:36 PM
thatdudety's Avatar
i dont have cams or bigger injectors but mine did that... when it would idle like that.. it was my throttle body.
Old Jun 9, 2008 | 10:09 PM
flyingwangwang's Avatar
That sucks doesn't it. Well, I got some "HKS" 272 cams to sell back to you if you want them! Thanks for some fake @$$ cams!
Old Jun 9, 2008 | 10:21 PM
dude's Avatar
Ouch, that stings. Maybe you can give him some free advice on how to fix his idle though, seeing as how 2 wrongs don't make a right...
Old Jun 9, 2008 | 10:25 PM
Wicked E's Avatar
In the desired Idle table, set all values to 400. Then in your timing table, set the upper left area of the map values to 20.
This should teach you a lesson for scamming a good member of this forum. Karma is a ***** and you ****ed with the wrong guy...
-E
Evo47
Mar 30, 2017 07:29 AM
mrm95
Nov 1, 2014 09:30 AM
jwick76
Lancer Engine Management / Tuning Forums
Dec 12, 2012 09:54 AM
murderedevo256
21
Apr 1, 2010 07:54 PM
vonzipper
13
Jun 19, 2005 11:44 PM
