Question for tephra, others. RE: map header addition factors
Old Jun 14, 2008 | 06:33 AM
Gatecrasher R/T's Avatar
This question was prompted by my own disassembly of an older ECU, and was partially answered in this thread:
http://www.aktivematrix.com/forum/vi...t=table+header
Originally Posted by tephra
ok from the top
3 = 3d map, 2 would indicate 2d map
14 = addition value that gets applied to the values that are retrieved, ie for ignition timing maps its 0x14 (add 20), for fuel maps it will be 0
ffff877c = memory variable to use to lookup up 1 axis
ffff877e = memory variable to use to lookup up the other axis
13 = the number of elements in the X axis...
the axis definition contains the other axis element number...
My question is in regard to the 2nd byte in the header. The addition value of 14. What does this mean? What effect does it have on the ECU's interpretation of the map? The definition files for ECUFlash just display the unaltered decimal equivalent of the raw hex values.
The reason I ask is this. I've got ROM dumps from various 3000GTs. The one I'm working on is from a 1995 (Mitsu 7793 CPU), and it has this for its high octane ignition header.
34 FC 0E FD 14 (little endian format)
FC34 - Address of X-axis
FD14 - Address of Y-axis
14 - Addition factor
The fuel maps use 00 for the last byte, consistent with the Evo. The MH7202F based 98 and 99 cars also use these addition factors, though the header format is slightly different.
A more detailed explanation would be very much appreciated
Old Jun 14, 2008 | 07:47 AM
tephra's Avatar
not sure, in evo world the addition factor (14 above) gets added onto whatever the result is in the map.
your example seems a little odd, can you put some more hex up?
Old Jun 14, 2008 | 06:53 PM
Sorry about that. I just realized the typo probably ruined the whole thing.
Here's the first few bytes for all three of our timing maps (the whole map is 20x15).
0xF620 :34 FC 0E FD 14 <--------Map header
0xF625 :0F 0F 0F 14 1A 1D 1F 21 22 23 24 25 26 27 28 29 2A 2B 2C 2C <--------First row of timing map
0xF751 :34 FC 0E FD 14 <--------Map header
0xF756 :0F 0F 0F 14 1A 1D 1F 21 22 23 24 25 26 27 28 29 2A 2B 2C 2C <--------First row of timing map
0xF882 :34 FC 0E FD 14 <--------Map header
0xF887 :0F 0F 0F 14 1A 1D 1F 21 22 23 24 25 26 27 28 29 2A 2B 2C 2C <--------First row of timing map
So the header SHOULD read...
FD0E - Address of Y-axis
The fuel maps all read xx xx yy yy 00. No addition factor.
So all I'm trying to get at is this. On the Evo, if you've got a cell with value 0F (decimal 15) the ECU is actually using a baseline ignition advance of 29 degrees (prior to any other correction factors being added) ?
Old Jun 14, 2008 | 09:19 PM
tephra's Avatar
0f + 14 = 23 hex = 35dec.
yes thats how it works on evo.
Not sure if its the same on your ECU - would need to look at the disasm...
Old Jun 14, 2008 | 09:50 PM
Cool. Thanks. I just wanted to be sure what I'm looking for. Sadly enough, our cars were out of production before yours were even officially introduced to this country...and we're still way behind the Evo crowd. I'm one of maybe 2 or 3 guys even bothering to work on this.
Old Jun 14, 2008 | 09:57 PM
tephra's Avatar
well if you need some specific help let me know... always happy to help
Old Jun 16, 2008 | 12:25 AM
tephra's Avatar
just thinking about this again, are you sure the 0x14 isn't the size of the map's x/y axis?
Old Jun 16, 2008 | 01:37 AM
JoeBee's Avatar
No, its an adder.
You can see it in the ign Table. The 0x14 (20 dez) ist the adder for the ignition table values, to keep them in a positive range.
Code:
ROM:00003B7A Ign_high_Table: .data.b    3            ; DATA XREF: ROM:Ign_high_Addr1o
ROM:00003B7A                                         ; ROM:00006138o ...
ROM:00003B7B                 .data.b h'14              adder
ROM:00003B7C                 .data.l RPM_Tab_Find
ROM:00003B80                 .data.l Load_Tab_Find
ROM:00003B84                 .data.b h'13              row/col size
ROM:00003B85                 .data.b    5                first Value pointed to in ecuflash
ROM:00003B86                 .data.b    5
ROM:00000C3A                 mov.b   @(1,r1), r0     ; r9=r0= 2 tes Byte = 0 in fuel
ROM:00000C3C                 extu.b  r0, r9
ROM:00000C9C                 add     r9, r4
ROM:00000C9E                 extu.b  r4, r4
ROM:00000CA0                 mov.b   @(1,r8), r0     ; Wert danach ebenfalls
ROM:00000CA2                 add     r9, r0
ROM:00000CA4                 bsr     sub_D7A         ; Mittelwert der zweiten Spalte
ROM:00000CA6                 extu.b  r0, r5
Old Jun 16, 2008 | 04:03 AM
MalibuJack's Avatar
I thought the same thing..
Boosted Tuning
Aug 26, 2023 10:14 PM
mrfred
Dec 15, 2022 11:13 AM
mrfred
Sep 14, 2022 07:08 PM
mrfred
Aug 1, 2022 06:05 AM
tephra
May 16, 2016 09:24 PM
