Comparison graph of boost before and after O2 and Manifold install (91 octane)
Old Jul 15, 2008 | 05:25 PM
  #76
RazorLab's Avatar
Originally Posted by roger smith
Now that I think of it, I get unstable boost curves. Even though my WGDC curve is gradually ascending my boost/load will fluctuate up and down. That's one more test I can do after I install my turbo outlet.
What are you using to log your boost? Care to post a boost plot?
Old Jul 15, 2008 | 06:15 PM
  #77
Jeff_Jeske's Avatar
I'm gonna stop arguing about it. All I can do is tell you I and several other locals had very bad luck with those things. I do wish you the best though. I didn't have the Titek piece.
I wish Razorlab would post his opinion of it. He's tuned and dyno'd many more cars than I have.
Old Jul 15, 2008 | 06:28 PM
  #78
RazorLab's Avatar
I've never done a A to B comparison of it as most customers install one with a turbo swap.
I can tell you however my personal Evo still has the highest HP on 100 oct with a FPgreen on our dyno so far. Obviously I push my car a tad more than customers cars but what is worthy of note is that my car is still on the stock 02 housing and I have nothing ported.
Old Jul 16, 2008 | 07:56 AM
  #79
roger smith's Avatar
I'll try to find a boost/load curve with corresponding WGDC curve. Oh it could be my 9.8 hotside too now that I think of it. hehe
To all, if you get stable boost rather than fluctuating it will surely make you out-accelerate a car with fluctuating boost.
Example,
Car A has fluctuating boost
Car B has stable boost
Car A boost, 10 15 20 22 22 22 22 22 21 19
Car B boost, 10 15 20 22 20 21 22 21 21 19
In the end Car A had stock turbo outlet, Car B had aftermarket turbo outlet.
This is all theory though as no one has before and after data of changing turbo outlets. Chamama's car is obviously out-accelerating his before car. Problem is who knows what helped to get him his current boost curve.
Old Jul 16, 2008 | 01:07 PM
  #80
Here are a couple of most recent data.
ECU+ is used to log everything. MAP sensor is GM 3-bar. Load is 2-byte.
You can see from about 4000-5000 there is a fluctuation in boost even though the WGDC is constant (boost error correction is off).
So is it due to my 16G-9.8T or the stock turbo outlet? Or something totally different (like the cat)?
Mods: downpipe, 200 cell cat, cat-back
Attached Thumbnails Comparison graph of boost before and after O2 and Manifold install (91 octane)-boost_wgdc_01.gif   Comparison graph of boost before and after O2 and Manifold install (91 octane)-boost_wgdc_02.gif
Old Jul 16, 2008 | 04:25 PM
  #81
RazorLab's Avatar
Bump up the WGDC a little bit in that section. Remember you can rescale the RPM in the WGDC table so you can give yourself a little more resolution in sections like those.
Old Jul 17, 2008 | 06:00 AM
  #82
juyanith's Avatar
I have an '03 VIII with 3" exhaust, no cat, HKS 272s, and 10.5 hotside. I still see the dip right around 4500. As far as I can see, it's just a characteristic of the engine.
Old Jul 17, 2008 | 06:36 AM
  #83
evo828's Avatar
boost dip
on my 2004 edm evo VIII - 3" turboback and free-flow cone filter - I see the same dip in the boost- do not know how to cure it (WGDC is 100% over there all the time)
Attached Thumbnails Comparison graph of boost before and after O2 and Manifold install (91 octane)-log.jpg
Old Jul 17, 2008 | 07:57 AM
  #84
I will try and post results. Thanks for the input.
Thinking of the dynamics of everything I can't explain why the WGDC curve would have to bump up like that. In theory if you left WGDC at a certain number through the whole RPM band then boost/load should hit some peak and fall off.
Does your car do this, Bryan? Or maybe it's just with 03s?
ddevox
Apr 28, 2017 03:41 PM
tscompusa
Aug 5, 2016 11:36 AM
RallySport Direct
Evo X How Tos / Installations
40
Aug 17, 2015 07:46 PM
Evil94
Mar 31, 2008 08:42 PM
kikiboi
For Sale - Cars For Sale
Dec 22, 2007 02:49 PM
