Tactrix Boost Control Solenoid (Plug-n-Play for Mitsu)
Old Sep 19, 2008 | 08:26 PM
  #136
brandEvO's Avatar
I'm an idiot to this so I need it put very simply. I'm not worried about the tuning portion of it, but I have the 3 port and have installed it. I basically hooked it up like the 2 port with leaving the compressor port not hooked up. From what I remember, isn't there a tee going from the wastegate and the compressor off of one of the original ports on the 2 port? If so, do I just run a vacuum line from the compressor port on the new solenoid to the turbo and basically take out the tee?
Old Sep 26, 2008 | 07:47 AM
  #137
mrfred's Avatar
Originally Posted by mrfred
Has anyone measured the resistance of the Prodrive BCS?
I picked up a Prodrive BCS. Resistance is 23.5 ohms whereas the stock BCS is 33.6 ohms. What is the resistance of the GM BCS?
Old Sep 26, 2008 | 04:05 PM
  #138
fostytou's Avatar
EvoM Community Team
MAC/AEM is ~13 ohms if I remember correctly
Old Sep 26, 2008 | 05:13 PM
  #139
mrfred's Avatar
I found the resistance of the GM BCS on NASIOC: 24 ohms
Old Nov 23, 2008 | 07:05 AM
  #140
mscorei's Avatar
is this better than a MBC? on the MBC you just set the boost at the desired level and have to modify it from times to times, but here it looks like you have a lot of work modifying maps. so is it worh it? in terms of boost/power.. it's a question.
Old Nov 23, 2008 | 07:39 AM
  #141
mrfred's Avatar
Depends on who you talk to. Most people who have the compentence and patience to tune the stock boost control system love it. The Tactrix BCS is not the best choice though.
Old Nov 24, 2008 | 12:28 PM
  #142
eTiLiKo's Avatar
Can I ask you why?
I was thinking about what BCS to choose instead of the stock one,only to try something different,your opinion will be much appreciated
Old Nov 24, 2008 | 02:09 PM
  #143
mrfred's Avatar
Originally Posted by eTiLiKo
Can I ask you why?
Check out this thread:
https://www.evolutionm.net/forums/sh...d.php?t=379043
Old Nov 25, 2008 | 05:50 AM
  #144
eTiLiKo's Avatar
Very exhaustive test,thanks a lot
I'll make you some questions on that thread
Old May 8, 2010 | 03:13 AM
  #145
in1t's Avatar
Hi guys,
are there are any differences between installing Tactrix 3-ports solenoid and GM 3-ports solenoid on Evo5 JDM?
I have installed one (like in this post) and still can't get it work.. Here is my situation:
If I connect it without resistor it looks like fine, the car is over-boosting like it should, but when I make changes in ROM (as described here or here), there are no changes in boost after reflash, it's still over-boosting for about 1.6bar =\
If I connect the solenoid using resistor, the car boost for about 0.6bar and there are also no changes after reflashing. Looks like Tactrix BCS doesn't work at all with resistor (I have the same effect if I disconnect power from it at all). Resistance of stock BCS on this Evo5 is about 72 ohms, the Tactrix BCS is 24 ohms, so I decided to use 47 ohms resistor on the ground wire.
What I'm doing wrong? Any help will very appreciated.
Old May 8, 2010 | 04:38 PM
  #146
merlin.oz's Avatar
loose the resistor.
maperformance
Dec 16, 2014 04:57 PM
hawaiian_evo
50
Nov 26, 2013 08:52 PM
Mellon Racing
Vendor Classifieds
406
May 24, 2013 05:53 PM
Dan@Assaultech
55
May 29, 2012 09:24 AM
lapulapu
Sep 9, 2008 05:52 PM
