swapper ecu?
Old Jul 9, 2008 | 07:25 PM
mrb00st's Avatar
swapper ecu?
i downloaded the map from my ecu, and it read "year:2004" .. but my car is a 2003? i checked the date code on the door and its a 03/03... which would make it a 03. does this mean some1 has switched ecu's in it before? and would that hurt anything running a different year evo VIII ecu?
Old Jul 9, 2008 | 07:31 PM
FloopyDisk's Avatar
+1
Mine did that too, my ECU was swapped with another 03 ECU supposedly, but it says it's 2004 too.
Old Jul 9, 2008 | 08:14 PM
cpoevo's Avatar
That is normal for the 2003 Evo's mine is the same way.
Old Jul 10, 2008 | 06:58 AM
logic's Avatar
Just as another data point (mainly for the archives, so people searching for this catch it): certain tuners change the ECU ID to something different and/or invalid when they flash an ECU, presumably as some sort of rudimentary copy protection. My Evo is a 2005, but EcuFlash showed it as having a 2004 ECU ID, and the maps were pretty generally mangled; changing the ECU ID to the correct one, 96940011 in my case, resolved the problem. Whether this kind of thing is still common practice by a few folks, I couldn't tell you.
If your maps all look fine, I wouldn't worry about it.
GhostLancer03
Lancer Engine Tech
Mar 4, 2012 11:51 AM
Ronnie Size
May 19, 2011 03:42 PM
eclipzed
Dec 22, 2008 02:59 PM
Cirrusly Evolvd
Mar 9, 2007 12:18 AM
conphuzed
Feb 5, 2006 02:35 PM
