Patch needed: run less than -10 degrees
Old Jul 10, 2008 | 06:02 AM
kkarim's Avatar
Well basically no matter what is says in your ignition tables, the ecu doesn't run less than -10 degrees.
Some of us are trying to make ALS systems work on their cars with the stock ECU and to do this we need to be able to run less than -10 degrees..
If any of the disassembly gurus can jump in and fix this for us, it would really be great...
Old Jul 10, 2008 | 08:27 AM
jcsbanks's Avatar
I'm not at all optimistic about this being remotely easy to achieve because of the vast amount of code the ECU uses to control timing, its seems endless when you look at it, and based on DSM disassembly (things are usually a development of the DSM) it probably uses different routines for different timing angles because sync points from the cam or crank sensors will be different depending on the timing requested. I don't think it is as simple as just removing a "-10" limiter.
The one person that has a cat in hell's chance of knowing is "Bez Bashni".
Old Jul 10, 2008 | 08:43 AM
TouringBubble's Avatar
I seem to remember a quick fix for the VIII's limit of -6º. I could be wrong though ...
Old Jul 10, 2008 | 10:42 AM
kkarim's Avatar
I didn't think it would be this complicated...
If any of you gurus would wanna take a stab at it, i'm sure you'd be helping a big bunch of people...
I guess i'll wait a couple of days, see what happens here and try to contact bez, see if he has anything to say about that.
David Buschur
413
Dec 28, 2017 09:11 AM
Ralliartize It
393
Jul 29, 2016 09:29 PM
evl gsr
Apr 20, 2016 11:57 AM
Ferp
Sep 15, 2015 08:52 AM
xhomm02
12
Jun 4, 2013 04:57 AM
