How can I increase EVO IX Lauch Control Limit?
Old Jul 17, 2008 | 06:57 AM
JugoSX's Avatar
I now tune an EDM EVO IX. Stock Launch Limit is 5500RPM, which sometimes not enough. I cant find, where can I change it. Can help somebody?
Old Jul 17, 2008 | 06:59 AM
MR Turco's Avatar
if you have ECUflash and a tachrix cable, pull the rom and change the Stationary Rev Limit
Old Jul 17, 2008 | 08:34 AM
JugoSX's Avatar
Unhappy
I already tried it, but nothing happend.
Old Jul 17, 2008 | 04:17 PM
EvoBroMA's Avatar
did you write the modified rom back to the ECU?
Old Jul 17, 2008 | 11:48 PM
JugoSX's Avatar
Yes, I Upload the modificated versions. Every changes is succesfull, ignition, fuel, tables, Rev limits, everything except launch limits.
Old Jul 18, 2008 | 12:30 AM
tephra's Avatar
bad definition probably...
Old Jul 18, 2008 | 05:32 AM
JugoSX's Avatar
How can I solve the problem?
Old Jul 18, 2008 | 08:21 AM
tephra's Avatar
post up what the value was BEFORE you changed it?
was it 5500?
Old Jul 18, 2008 | 09:13 AM
JugoSX's Avatar
was it 5500?
I wrote 5500 the RPM. Really is it just 5200. Stock value was in the field 2250 I changed it many times, to 2000, 2500, 3000 , 5000, 7000, and always nothing happend.
Old Jul 18, 2008 | 10:23 AM
92gsxbaltimore's Avatar
Stock value should be 5000 rpms, not 5500. Make sure you are editing the "stationary rev limit" value
Old Jul 18, 2008 | 11:08 PM
tephra's Avatar
lol - so you assumed that 2250 = 5000?
no...
if the value you are changing doesn't "appear" correct (ie 2250 is clearly not 5500 or 5000) then dont change it.
post up your definition for the stat rev limit, ie the address its using, and you romid...
Old Jul 19, 2008 | 08:14 AM
HoP's Avatar
HoP
I'm guessing you are running a 88840016 rom becourse it has the wrong address in ecuflash. The address should be 274a
Old Jul 26, 2008 | 02:21 AM
JugoSX's Avatar
Thumbs up
HoP was right, there was wrong address problem. I adjust correct address, and change units to RPM, and now can I use this function.
Thanks help for everyone!
Old Jul 26, 2008 | 03:28 AM
JoeBee's Avatar
Just to remember. Dont forget to change back the former changed wrong values.
Maybee use a backup. Because you dont know what you have changed there.
KameloT
Mar 29, 2013 04:28 PM
DonMitsu
South Region
Sep 20, 2011 08:13 PM
I4UnderPressure
Jan 4, 2009 07:55 AM
bondango
Jun 9, 2008 01:35 AM
