My First tune..take a look please
I have been reading for about 10 hours...looked at lots of maps. This is what I came up with for my IX, 23 psi on 93 Octane. I just want some honest opinions on if this is safe. I have a wide band and Evo Scan so I know whats going on...I just want to know if you think this would be a safe start.
Thanks!
Thanks!
I also have the Tephra patch so I know if its knocking.
I have not diabled lean spool yet...I want to make sure I do it right....can I just set the start stop to 1500 and be done?
timing looks very good comparing it to my old stock turbo maps, quite conservative i would even say...
fuel i would try to stay 11.5 afrs and down...
as said previously, make a couple of logs and share the feedback...
looks decent.
id do some smooth, look at ur logs, where you ramp through some midrange load sites, you may want to smooth the timing a little more... the one column you go 6,,7,6,7,6,78... you more than likely can just run 7 degrees there etc...
cb
cb
Cool, thanks for the input. I need to get my damn KeySpan serial/usb converter from my buddy so I can log with the wideband. I did a 3rd gear (no logging) pull after I loaded this tune...no Knock light at all.
On a second note, my car somtimes dies when I am crusing. I will slow down to come to a stop light and the car will die....this only happens When I got the AC on.
Marroccowned
Jul 4, 2010 04:58 PM
