patch for 88590015: control front and rear O2 with wideband
#47
What I basically am trying to do is hook up the LC-1 to be the primary front O2 sensor. I've simply wired in the analog output #1 (I assume it doesn't matter between #1 and #2?) in place of the stock O2 sensor. This in turn simulates the narrowband sensor, correct. Nothing further is required using the LC-1 (ie. alterations in the LM Programmer)? I am aware of the switch over point alteration that can be done for better fuel economy but, i am just confirming the simulation portion of the this.
As far as logging from it is concerned, I've only had a few issues in the beginning logging via serial but, it turned out to be my own mistake in the LM Programmer.
#49
EvoM Community Team
Hi MrFred. I noticed the current version posted is for v6t. It looks like the subroutine values are different in this rom compared to the v5.10 rom I had previously (both from this thread and running on my car).
Was the code updated for v6t? Any predicted incompatibilities with V7?
#50
EvoM Community Team
I'll assume the changes between what I was looking at were between v6 v6t and not between what I was actually looking at.
mrfred
Sep 14, 2022 07:08 PM
