TephraMOD V5.10
Sounds like you turned off the rear 02 with the periphery, which turns the rear O2 to not ready and the catalytic converter also. I suggest you turn it back on, and if you don't have a rear O2 installed, get the right resistor. Also, turn on tephra's rear O2 simulator to pass the catalyst test. That should address all 3 problems.
And download/install scantech so you know when everything passes before making another trip to an inspection station.
so what your saying is that when the patch was put in it was totally disabled and not stimulated????? and also i downloaded tephra's files but i have no idea how ot use them yet so if there is a how to id love to read up on it lol
also where can i get the scantech download ? and thanks for the help
the only scantech download i found was on the aktivematrix.com web site but after downloading it it does not work no matter what application i open it with it just comes out all in jibberish
Tephra i am a friend of silver9mr that flashed in the Periphery0 for him. I didn't realize that it is just a disable and not a simulator. i will be looking now to remove that and run your set-up.
I have a 0008 rom currently. I will be doing some reading through ur threads tomorow but just a quick review... I should be able to run your mod on my evo 8 and his 9 but with this change the rom id # or does it remain the same. Also your NLTS and valet mode are optional correct, like u don't have to have all the features active..
A friend of mine hooked me up with cel to flash when knocking back when i first got my evo when i knew nothing about them. Does that mean i already have ur mod or is there also another mod for cel to flash?
sry if that was confusing.. thanks in advance
94170008 can be upgraded to 94170015 - thats for evo8.
evo9 will need to run 88590015.
Yes you can disable the features you don't want/need.
You must have an early version of my mod - you will need to clean out the old xml from your ecuflash definitions before loading up the new mod.
You will need to use the base rom's on post #1 and then copy your maps to it.
ok - set the valet RPM limitter to 3000rpm...
sometimes with 96530006 it stuffs up the valet thing... not sure whats going on there as it never happens on my car
THE CAR START!!!!
