TephraMOD V5.10
Old Sep 8, 2009 | 02:50 PM
  #1201
Mellon Racing's Avatar
oops, I see my flaw now, the tephra supplied xml doesn't contain everything, just the tephra piece of the .xml
Old Sep 8, 2009 | 04:19 PM
  #1202
tephra's Avatar
yup
this is changing in V7... to make it easier
Old Sep 20, 2009 | 10:14 AM
  #1203
rdtech's Avatar
Originally Posted by tephra
yup
When is version 7 coming out tephra? btw- great work!
Old Sep 20, 2009 | 02:11 PM
  #1204
kaj's Avatar
kaj
i was wondering... when it comes to the ACD pump.. is there a way to activate it so we can make sure it works? i mean.. i know the key/gas pedal trick.. but like how we can activate the fans, fuel pump, etc...? i just thought it would be kinda cool to have. it would have helped me when i was trying to figure out my infamous "all three ACD lights are on" issue.
Old Sep 23, 2009 | 02:08 AM
  #1205
Armanc1's Avatar
Would be interested as well!
Old Sep 23, 2009 | 02:17 AM
  #1206
tephra's Avatar
just waiting on some feedback from the testers on 1 bug and then its a go
Old Sep 23, 2009 | 02:25 AM
  #1207
Armanc1's Avatar
Excellent news! Probbably I have been under a rock, but will there be 88840016 support as well?
Old Sep 23, 2009 | 02:27 AM
  #1208
tephra's Avatar
88840017 will be included.
initially the roms will be 96530006 and 88590015 - i will then do romid's as requests and such come in
Old Sep 23, 2009 | 02:35 AM
  #1209
Armanc1's Avatar
Many thanks, Tepra! Thought to ask The Guru himself..... Is it so that I can simply reflash the 88840016 ECU with 88840017 V7 mod?
Old Sep 23, 2009 | 02:36 AM
  #1210
tephra's Avatar
should be able to..
see how some of the other 8884* guys go with using 8859 over the top..
if they dont get any CEL's and it runs ok then that will be easier for me
Old Sep 23, 2009 | 02:42 AM
  #1211
cossie1's Avatar
Don't forget the earlier requests for 90550001
  #1212
Armanc1's Avatar
should be able to..
Excellent, thanks for the support! Great help! I will defenitely give it a try as soon as the V7 is available.
Old Sep 23, 2009 | 03:03 AM
  #1213
tephra's Avatar
no worries cos
Old Oct 3, 2009 | 08:22 AM
  #1214
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Tephra I downloaded your patch for 96530006 I was reading the notes in the XML file and I don't understand a few of the notes. Specifically:
2) Remove/Rename your current "Boost Desired Engine Load" #2 and #3, only #1 matters anymore
3) Remove/Rename your current "Base Wastegate Duty" #2 and #3, only #1 matters anymore
4) Remove/Rename your current Hi/Lo Octane Fuel+Timing #2 and #3, only #1 matters anymore
Can you or anyone else elaborate on those 3 steps?
Thanks
Old Oct 3, 2009 | 08:32 AM
  #1215
kaj's Avatar
kaj
Lol. The verbage is confusing. There are many posts in regards to that section. I, too, was very confused. I didn't have the tables mentioned, nor did I know what to do with them if I tried. Lol I think the tephramod has all that stuff removed already, as all I have are "high octane", "low octane", etc.
Thanks
