having problems with knock
Old Aug 14, 2008 | 06:53 AM
Fastlaser92's Avatar
I have an evo 8 with basic bolts catless tbe, mbc, intake, and licp. For some reason Im getting 3 to 4 counts of knock and timing is being retarded, if someone knows how to get rid of this it would help me out alot thanks. here is the timing and fuel maps
Old Aug 14, 2008 | 11:35 AM
travman's Avatar
did u tune that yourself or is that done by a "tuner"
Old Aug 14, 2008 | 11:47 AM
Originally Posted by travman
you need a better tune the timing map is all over the place.....that is why its knocking.
I did it myself, but the map itself is pretty much stock, since it was knocking didnt really advance the timing. I just tried to retard some of the timing where it was knocking but doesnt seem to be taking out the knock since the timing still is negative. I guess I could try working on it more.
Old Aug 14, 2008 | 11:49 AM
travman's Avatar
yeah your all over the place.......
Old Aug 14, 2008 | 12:18 PM
Evo_Pma's Avatar
what are your mods?
Old Aug 14, 2008 | 12:30 PM
travman's Avatar
actually read the original post and not just the title and ye shal find the answers.
Old Aug 14, 2008 | 01:14 PM
you think if i take some more timming out it will stop the knock?
Old Aug 14, 2008 | 01:22 PM
RedLanEVO's Avatar
smooth out ur timing map using ecuflash's graph. there was a thread started by jack-of-trades that explains how to use it. basically your timing jumps too much. ie: one cell is 5 and the cell next to it is 3 then 5 again so etc.
here
https://www.evolutionm.net/forums/sh...d.php?t=362921
Old Aug 14, 2008 | 03:15 PM
G20's Avatar
G20
open the logged file in Excel and try to modify the timing map such that the timing start out from 2-3* at around 3500 when you hit full boost and gradually step up to 11-13* after 7000 rpm. The smooth timing transaction will help reduce the knocks to minimal.
Old Aug 15, 2008 | 02:05 PM
ok i guess will see what happens becuase I just put an evo 9 turbo and megan racing o2 housing in.
Old Aug 15, 2008 | 02:10 PM
Mellon Racing's Avatar
like they said, the timing map is very rough.
Old Aug 15, 2008 | 02:36 PM
dude's Avatar
You also might want to rescale your load axis, looks like you are trying to pull timing out of cells on the upper limits of your load range.
Old Aug 15, 2008 | 02:41 PM
yea i was thinking of doing it to 300, but i just wanted to get rid of the knock, i dont know what it is, like the more timing i pull it doesnt do anything still -4 degrees of timing, i dont understand it.
Old Aug 15, 2008 | 03:27 PM
G20's Avatar
G20
maybe you were modifying the wrong load cells. An intake can make your log reporting wrong load cells. For example, in the log it's 5500 rpm at 280 load when it was actually at 240 load cell. It's easy to tell by enter some fairly large delta value at the cell to see if it'll change. Like enter a richer number into a logging cell in the fuel table to see that spot will actually richer when logging.
Old Aug 15, 2008 | 06:36 PM
rsboy's Avatar
speaking of load axis...newbie question...
does the load % on the fuel maps and the timing maps have to match with each other? I've seen roms where the fuel map has 10-100, 120, 140, etc till 260 but then the timing map has 0-60, 80, 100, 120, 140, 160 so forth, then up to 300. 70 and 90 columns were missing.
