Dyno tuning; tail pipe or LC-1 best?
Old Aug 19, 2008 | 08:03 AM
Chemwarrior's Avatar
I've noticed that a lot of tuners use the tail pipe for measuring AFRs when tuning on a dyno. If a car has a wideband would it be better to measure the AFRs from the wideband or use the calibrated tail pipe sniffer?
Old Aug 19, 2008 | 08:04 AM
derekste's Avatar
If both are calibrated, there shouldn't be any difference.
My LC-1 was spot on compared to the sniffer the last time I was at AMS.
Old Aug 19, 2008 | 09:35 AM
Thanks for the response. I know there is only a few feet difference between the LC-1 sensor and the tail pipe sniffer but I was concerned that the tail pipe sniffer might not get as an accurate reading.
Old Aug 19, 2008 | 09:49 AM
silver_evo's Avatar
If you have any leaky gaskets between the lc-1 and the sniffer, the sniffer will read more lean (due to fresh air being venturied into the exhaust pipe)
Old Aug 19, 2008 | 11:13 AM
steadly2004's Avatar
Wouldn't the catalytic converter screw up the tailpipe reading? I mean most wideband manuals specify the sensor to be placed before the cat.
Old Aug 19, 2008 | 01:43 PM
bboypuertoroc's Avatar
Veteran: Army
^ That's IF there is a cat.
I would say the LC-1 would be the best to read off of. Especially if you do any logging when NOT on the dyno since that's the only reading you'll be getting to work with.
Old Aug 19, 2008 | 03:19 PM
I do have a high flow cat and my LC-1 is obviously before that.
Thanks for the input guys.
ODUB
Jun 6, 2016 11:17 PM
extremepsi
Jan 17, 2016 12:09 PM
tscompusa
Evo X Dyno Results
15
Apr 29, 2013 01:56 PM
ChrisGST
Jan 8, 2011 07:07 PM
evane
Dec 30, 2008 06:47 PM
