downloaded the AYC/ACD ROM
Old Mar 22, 2009 | 02:23 AM
  #76
joyce1bro's Avatar
Originally Posted by sba
There is only one ecu for both.
not in mine.... evo V
Old Mar 22, 2009 | 09:02 AM
  #77
sba's Avatar
sba
Originally Posted by fostytou
I can definitely host the file for you if you need... plenty of space and bandwidth. PM me for an email addy.
Also, if you wouldn't mind sharing some info with tephra, JCSBanks, MrFred or anyone else on how to read/write/interpret that would be great!
I have to get Monday on office to get the file. And i will send it to you.
Old Mar 22, 2009 | 02:51 PM
  #78
JoeBee's Avatar
I'm able to read the AYC Ecu. I readed a stock one and a Ralliart. I also can write then how i wish.
I'm working in the chiptuning company and i have a tool that makes also this ecus.
Unfortunately, i'm in Romania which pretty far.
But if somebody really wants, i can write anything that he wants inside the AYC ecu. I will also post a bin file of a stock ecu for the dissansembly guys.
NOW
Ralliart has 5 types of AYC ecus. I put my hands only on K2 model which is for gravel rallies.
Did anybody used something different??? I'm curious which is the best AYC variant for road?
If somebody has any ideas, i'm opened to anything
Hi from Germany.
How did you read out the ROM? What interface are you using?
Did you know what processor is used in the ACD/AYC?
Is the ROM placed in the processor flash ore external flash?
So many questions
Old Mar 23, 2009 | 08:09 AM
  #79
sba's Avatar
sba
Hello,
I did readed it out using a serial tool (i cannot tell you the name of the tool because it is company secret)
Inside you will find out a MH7203FA processor and from what know, the rom is inside the processor.
And i needed only 2 wires to read out the rom, and 12v and ground.
Old Mar 23, 2009 | 09:46 AM
  #80
rolly1818's Avatar
Registered User
hold on in this thread are we talking AYC or ACD???
Old Mar 23, 2009 | 09:53 AM
  #81
fixem2's Avatar
AYC/ACD are on the same ECU/processor. This is from a previous post.
Old Mar 23, 2009 | 10:17 AM
  #82
sba's Avatar
sba
Does somebody have the pin-out for the ACD ecu???
Old Mar 23, 2009 | 10:23 AM
  #83
logic's Avatar
MH7203FA would make it the same processor as a 1998-2000 Eclipse, as near as I can tell; ie. an H8/539F.
From doing some beginning work on disassembling a 1999 DSM ROM, IDA Pro's H8/500 processor module seems to do the trick for it, if anyone starts playing around with pulling the ROM off of it.
Old Mar 23, 2009 | 10:28 AM
  #84
fixem2's Avatar
Looking at the EcuFlash website, the program supports all 2nd Gen eclipses 1996 and up. If we can get the ROM and create an XML then Ecuflash maybe be able to work, but we still would need a cable and maybe more code in EcuFlash.
Old Mar 23, 2009 | 10:30 AM
  #85
kyoo's Avatar
https://www.evolutionm.net/forums/ev...available.html
Old Mar 23, 2009 | 10:31 AM
  #86
logic's Avatar
Datasheet: http://www.datasheetarchive.com/pdf-...DSA-336310.pdf (you might get redirected to the main page; just search for "H8/539F")
Programming app note
MCU datasheets: http://forums.openecu.org/viewtopic.php?t=172
Old Mar 23, 2009 | 10:47 AM
  #87
MR Turco's Avatar
I'd rather buy the do-luck controller for the price of the Gruppe-s flash.
Truthfully i would like to flash it myself but it seems off the roadmap for most of the guys that can hack this stuff. Very exciting non the less.
Old Mar 23, 2009 | 11:17 AM
  #88
kyoo's Avatar
The do-luck controller works for USDM cars?
I agree, this is an amazing upcoming development for ct9a cars
Old Mar 24, 2009 | 07:21 AM
  #89
sba's Avatar
sba
I don't have where to post the file. Give me PM and i send you the file. Now i'm in a pursuit of as many different acd ecus that i can find.
Now i have the K2 from ralliart.
Or if somebody has place to keep the file, i give it happily.
Let's see what we can do with it.
I also have a lot of maps for Motec and Gems ACD ecus for the rally and if we find a way to understand the bin inside our ecus, then we can implement already used files
Old Mar 24, 2009 | 07:28 AM
  #90
logic's Avatar
Megaupload for hosting it temporarily, perhaps?
