Need help Controlling Boost with GM Boost Selenoid
Old Aug 25, 2008 | 05:03 AM
Evoryder's Avatar
Originally Posted by razorlab
You have cams and a ported head, I doubt it will hold that kind of boost.
It's not a bad thing, boost isn't everything and doesn't tell the complete story.
Oh ok. Sig was misleading. You're right about the boost. The op will end up having to getting a bigger turbo if holding a certain amount till redline is a must
Old Aug 25, 2008 | 02:57 PM
Jumperalex's Avatar
Air temp matters to the tune ... but in the end, the most important thing is to get as much air into the engine as possible. That is what actually MAKES power. Sure cooler air, at the same mass flow rate, means better timing, but at some point we've reached max power (read efficiency).
The only thing to do then is increase the mass flow. We do that with boost pressure, which happens automatically with our boost control, until pressure gets too high, the air gets too hot again, or we simply run out of flow. But everything we do with these engines is geared towards flowing as much air as possible, while igniting the mixture in the most efficient way possible (AFR), at the best time possible (timing).
Cooler temps means more efficiency (thermal efficiency), but more air means more fuel which is a much bigger stick to wield than a few points of efficiency
mitsuorder
Sep 20, 2021 06:05 AM
850RCT9A
For Sale - Cars For Sale
Aug 15, 2011 02:31 PM
mugen777
19
Dec 23, 2008 07:11 PM
Gsxtremedsm
14
Jun 19, 2008 06:08 PM
Pd1
217
Jul 29, 2007 03:24 PM
