Need help Controlling Boost with GM Boost Selenoid
Old Aug 24, 2008 | 07:53 PM
03RRVIII's Avatar
i finally had a chance to tune my boost on the new selenoid, coming from MBC i decided to use the GM Boost Selenoid instead, but cant stop the boost from tapering up top. I decided to run 25psi of boost on my 100oct setup but no matter what i do it kept tapering from 25 to 21psi up top.... pls let me know where to make adjustments from here.....
MODS:
Ported Head
Ported Exhaust Manifold
Titek 02 housing
Stock VIII Turbo with 10.5 hotside
Turbo Back Exhaust with Test Pipe
Weapon R Upper/Lower Intercooler Pipings
Spearco FMIC
K&N Open Filter
RC 750 cc Injectors
Walboro Fuel Pump
Okada Coilpacks
NGK 1 Step Colder Spark Plug
100 oct fuel
or is my VIII turbo max out??
TIA
Old Aug 24, 2008 | 08:05 PM
RazorLab's Avatar
Nature of the turbo plus the ported head and cams as well.
Old Aug 24, 2008 | 08:21 PM
codgi's Avatar
When my wastegate hose was off last year on my car (TBE + bushcur header + K&N drop-in etc.) the stock 05 turbo would max around 29psi and taper to about 21/22 psi according to the JDM map. So if you want to hold 25 looks like you need to get a different turbo.
Old Aug 24, 2008 | 08:22 PM
03RRVIII's Avatar
its that mean stock turbo is really max out? so is time time to get a bigger turbo?
Old Aug 24, 2008 | 08:26 PM
tephra's Avatar
21psi @ redline is really the limit of the turbo.
and even then its out of its efficiency range.
if you want more than 20psi @ redline, get another turbo.
Old Aug 24, 2008 | 08:32 PM
RazorLab's Avatar
LIES!!!
Old Aug 24, 2008 | 08:40 PM
tephra's Avatar
ok first time ive seen anyone make more than 21ish...
how?
Old Aug 24, 2008 | 08:44 PM
RazorLab's Avatar
how?
Evo 8
Stock cams
Ported to hell turbo
GM 3 port
3" exhaust no muffler
(track car)
With cams and more flow the turbo won't hold that much.
Old Aug 24, 2008 | 09:35 PM
tephra's Avatar
oh well, ported turbo...
Old Aug 24, 2008 | 09:46 PM
03RRVIII's Avatar
so to hold more boost, instead of going to a different turbo, just get it ported and should hold atleast my boost all the way?
Old Aug 24, 2008 | 09:48 PM
Evoryder's Avatar
He's on stock cams + FP Green turbo. Guarantee if he throws on some cams he wont hold that boost. I hold 24-25psi @ redline from a 30psi spike(stock cams)
Old Aug 24, 2008 | 11:33 PM
RazorLab's Avatar
It is not a green, it is a stock turbo that has been ported. Why would I post a boost plot of a green when we are talking about a stock turbo?
Old Aug 24, 2008 | 11:34 PM
RazorLab's Avatar
You have cams and a ported head, I doubt it will hold that kind of boost.
It's not a bad thing, boost isn't everything and doesn't tell the complete story.
Old Aug 25, 2008 | 04:57 AM
Jumperalex's Avatar
in fact it tells none of the story. mass flow rate is the only story. no matter what the point is to get more air into the motor. I know I'm not telling you anything razor, but sometimes it needs to be said that explicitly to everyone.
Old Aug 25, 2008 | 05:01 AM
tephra's Avatar
not really...
what about air temps?
