Knock Filter 1 is Purge Control?
Old Aug 31, 2008 | 03:24 PM
Mattjin's Avatar
I have been doing a bit of theorising on what the leftover 3D tables are in our roms. Independantly I figured out EGR duty are two of my "knock filter" tables, but afterwards found a thread already talking about this (I should have searched). So what do the rest of the tables do? Standing back and looking at the tables with an open tuners mind I am finding that the table labbelled in almost all of the roms as Knock Filter 1 seems to correspond to the documentation in the factory workshop manual about how the duty of the signal should be for Purge Control. Has anyone else found this to be the case, or better yet has anyone at all looked into it. Can any of the smarter people here find a way to Evoscan log the values used in Knock Filter 1.
The point is not in tuning the purge control which is rather useless for performance tuning, but rather to one-by-one eliminate the tables so we can zoom in on the real knock control system which is far more useful.
The workshop manual lists the system as referring to Airflow, Coolant Temp, Air Temp, and Baro Pressure.
Anyone?
Old Aug 31, 2008 | 05:00 PM
burgers22's Avatar
Would seem likely that the knock control would be referenced in some way by the timing, fuel and octane routines. Not a great help I know, but might give a starting point to start looking.
MB
Old Sep 1, 2008 | 03:05 AM
Mattjin's Avatar
Nah its not that. What I am getting at is that alot of the maps we have are mislabelled and the most common of the mislabelled maps are the so called knock filters. Only around half of them have anything to do with knock. EGR duty 3D maps are part of them, usually labelled as Knock Filter 2 or 3, or even both. Purge control is usually 3D mapped duty as well, and there are no more 3D maps left to decypher except for the Knock Filters. Part of getting the knock control... well... under control, is to eliminate what we dont need to control. So taking an overall look at Knock Filter 1 it looks alot like what would be expected for a purge control duty map. Baro Pressure (x) vs Engine Load (y) ?? I just need to do some logging of it to check.
Old Sep 1, 2008 | 06:50 AM
300477's Avatar
Guys here are the 5 purge maps.
purge cut
eq = ev*1.6
x=rpm
y=percentage
start = 44ec
end = 44f4
0 0rpm
0 500
0 1000
0 4000rpm
purge sol duty 1
5hz
equ = dt/50*255 units=percent
x=rpm
y=ev %
start = 4a45
end = 4a8a
10 500
20 750
30 1000
.. 1250
1500
1750
100 2000
purge sol duty 2
10hz
equ = dt/100*255 units=percent
x=rpm
y=ev %
start = 4a97
end = 4afa
10 500
20 750
30 1000
.. 1250
1500
1750
100 4000
purge sol duty 3
5hz
equ = r/12.5*256 units=percent
x=rpm
y=ev %
start = 4b07
end = 4b4c
10 500
20 750
30 1000
.. 1250
1500
1750
100 2000
purge sol duty 4
10hz
x=rpm
y=ev %
start = 4b59
end = 4bbc
10 500
20 750
30 1000
.. 1250
1500
1750
100 4000
base data 99860003
Old Sep 1, 2008 | 04:05 PM
Mattjin's Avatar
Are you sure about them? I would have thought it is over the top to use 4 full 3D maps just for purge. How were these maps found?
Thanks, I will do some testing and see how I go. In my rom they are labelled as Knock Filters 7,8,9,10 so it will keep me busy over the next few days. :-)
Old Sep 2, 2008 | 12:57 AM
Mattjin's Avatar
Well bugger me, you were right!!! My Knock Filter 7 and 8 are definitely Purge Control for 5Hz and 10Hz respectively. The other maps I am yet to test but they do look promising. That eliminates a bunch of maps, so I am quickly narrowing down the true knock maps.
Old Sep 2, 2008 | 07:04 AM
300477's Avatar
I wont say where i got them, but they WILL be right. Only mistakes would be my typos. LOL
What other maps are you guys looking for?
Old Sep 2, 2008 | 08:25 AM
ecuflasher's Avatar
Real knock control maps?
Old Sep 2, 2008 | 03:19 PM
Mattjin's Avatar
I found the tables corresponded to these axis. X = Load (10 to 100) and Y = RPM (0-2000 and 0-4000). With varying load I could remap and see an effect. This is done with a pressure gauge on the purge line to visually verify. Next step will be to scope the signal wire to the solenoid.
What is the exact purpose of the second set of 5Hz and 10Hz maps? It looks like some kind of maximum possible flow having larger numbers in the high vacuum (low load) areas.
Old Sep 2, 2008 | 05:26 PM
300477's Avatar
I'll ask.
Old Sep 3, 2008 | 08:29 PM
dude's Avatar
I'll ask.
Just curious, but who are you asking???
And when are all these corrections going to be reflected in ecuflash???
Old Sep 4, 2008 | 05:39 AM
300477's Avatar
Asking someone who is in the know and who is a bit internet shy. He is happy to help out when people get a bit stuck. Either with the maps or any of the functions. Im pretty sure he has all the functions too.
Not sure, does anyone know when a new version of ecuflash is coming out? If we can put in requests my tuner would love live tuning if possible.
Old Sep 4, 2008 | 06:41 AM
tephra's Avatar
hey Shane, live tuning will need ROM support.
jcsbanks already has a running demo of this - i have a copy but havn't tested it yet.
Old Sep 5, 2008 | 02:22 AM
300477's Avatar
Interesting. What ROM support is required? Hardware or a software patch?
This would be a huge step in resolving what i would consider one of the final differences between the factory and an aftermarket ecu.
Let me know how this goes. If we can offer up some testing yell out.
Im also going to chase up the Real knock maps.
mrfred
Aug 1, 2022 06:05 AM
PPM
Apr 2, 2015 09:35 AM
Jim in Tucson
Nov 21, 2010 09:29 AM
NOMIEZVR4
Oct 26, 2009 10:36 PM
Tuner@Swift
Aug 22, 2008 01:47 PM
