new feature in ECUFlash 1.35: periphery bits
Old Oct 17, 2008 | 07:46 AM
  #46
ciobing's Avatar
Originally Posted by MR Turco
My fault i was thinking FAA bit11 which disables EGR ignition advance. I was thinking they were separate.
Thanks that what i needed to know.
Sorry for my bud English understanding ..
I want disable EGR ignition advance and possibly EGR valve too,what must I do?
Old Oct 31, 2008 | 07:59 AM
  #47
derekste's Avatar
Originally Posted by fixem2
For Periphery bit FBA we are showing bit 7 as Lean Spool. Can someone verify that this is incorrect or correct? (ROM 96530006) I beleive Tephra is seeing Bit 0 as the "Lean Spool Enable/disable."
I would like to know this too!
Old Oct 31, 2008 | 08:49 AM
  #48
fixem2's Avatar
derek,
I believe it has been confirmed that the correct one it bit 0.
Old Oct 31, 2008 | 09:39 AM
  #49
honki24's Avatar
Will a dissasembler verify that please? Good to know. Also, does the bit control anything else?
Old Nov 3, 2008 | 07:03 AM
  #50
honki24's Avatar
Hi-oh!
Old Nov 3, 2008 | 09:54 AM
  #51
MR Turco's Avatar
FBA Bit 0 enables/disables lean spool according to tephra and has been tested to maintain the same AFRs as alternate Lean Spool disablement methods.
Old Nov 3, 2008 | 11:29 AM
  #52
lapulapu's Avatar
Which rom does this apply to?
Old Nov 3, 2008 | 01:00 PM
  #53
todd6027's Avatar
If you open ecu periphery1 highlight the value (std value 0009)and open ecu periphery 1(fba) , bit 0 is set to 1 , highlight the 1 and change it to 0 using minus key ,, watch 0009 change to 0008, in ecu periphery, lean spool disabled. works for me 98640014/90550001/93660005/94170008
Old Nov 4, 2008 | 05:31 AM
  #54
honki24's Avatar
Thank you very much for the confirmation.
Old Nov 4, 2008 | 05:53 AM
  #55
MR Turco's Avatar
All of them. Periphery bits are the same cross ROMs
Old Nov 16, 2008 | 12:20 AM
  #56
SPAWN's Avatar
subscribed
Old Nov 17, 2008 | 02:08 AM
  #57
Mattjin's Avatar
So which bit was it that turns off the knock control, I remember it is in Periphery0?
I may have found a way to keep the boost control running when the knock control is turned off too. Normally it turns off at the same time. I found the addresses which control the octane level the wastegate solenoid is enabled and disabled at.
Old Nov 20, 2008 | 05:56 PM
  #58
MR Turco's Avatar
I may have missed this but there are two bits for EVAP codes - FCA Bits 13 and 14. Should i disable both of them if i want to remove the EVAP system? Are those the only two bits associated with EVAP?
Old Nov 20, 2008 | 06:34 PM
  #59
logic's Avatar
Just an observation: while I was testing something and intending to toggle FAA bit 3 (immobilizer disabling), I accidentally toggled FAA bit 4 instead. The car behaved as though the ISC had been disabled; idle seemed to be driven by the setting of the BISS.
Just in case it helps anyone.
Old Dec 8, 2008 | 08:28 AM
  #60
MR Turco's Avatar
Bump - I am also looking to know if anyone had issue with emissions testing. I am mainly looking to remove the solenoid, not the canister. I am trying to remove the junk around the IM, specifically attached to that bracket. The new search feature is horrible but i tried looking for what you can keep attached. I remember something about as long as the solenoid is plugged in everything else can be removed.
