knock sum count
Old Sep 9, 2008 | 10:01 AM
mlancerevo8's Avatar
knock sum count
what is the best knock sum count... i have a sum count of 8 and 9... i was told it was fine and it runs better then it ever has before... please give me input...
Old Sep 9, 2008 | 10:05 AM
TeStUdO's Avatar
The best knock is 0 knock. With 8 and 9 counts, your ECU is pulling timing like crazy. I suggest a new tune with a COMPETENT tuner, and to never let whoever told you 8 or 9 counts of knock is fine touch your car.
Old Sep 9, 2008 | 10:06 AM
RazorLab's Avatar
Run away from whoever told you that was fine.
Old Sep 9, 2008 | 10:09 AM
lemmonhead's Avatar
hit him in the face 8 times
tell him knocksums are like punches to the face. you want ZERO if you can. So if he says 8 is ok, then hit him in the face 8 times. its hard or nearly impossible to get 0 everytime. But 1-2 on ocasion is nothing to be alarmed at. 8 at any time is BAD BAD BAD BAD BAD
Old Sep 9, 2008 | 10:28 AM
it was actaully a guy at a good named shop around my area... anyone have a email i could send the log to see if it is bad!!... it wasnts a full 4th gear pull it was a track log
Old Sep 9, 2008 | 10:30 AM
with a ttp engineering tune i got 8 and 9 count knock
Old Sep 9, 2008 | 10:35 AM
tim85851's Avatar
do what lemmonhead said...PUNCH the tuner in the face the amount of times your car knocked. you want 0! thats what people tune for! 0 knock counts = best. 1-2 counts = ok...hope you get that tune worked out...
Old Sep 9, 2008 | 11:01 AM
partyboy1122's Avatar
Post the log on here
Old Sep 9, 2008 | 11:25 AM
EatSleepBoost's Avatar
8 and 9 counts of knock is very poor. u r loosing way more power than u should be
Old Sep 9, 2008 | 11:44 AM
JohnBradley's Avatar
It all depends on when the knock happens. If it happens when you first roll into it, when shifting, or if you part throttle, and it rapidly decays i wouldnt be as worried as if it happened the entire pull.
Old Sep 9, 2008 | 11:45 AM
nonschlont's Avatar
It never ceases to amaze me what some "Tuners", from what we think is a respectable shop, will tell you, when they know you dont know enough to call them out on it! My first experience was as bad as this if not worse, cause the tuner didnt even tell me **** about my tune. Intake, DP, CB, FP. Here ya go 15hp and 20tq increase from stock!
I would talk to this so called tuner and see if you can get this squared away, but then again do you really want some1 like this to touch your car again... Anything over an "occasional" 1-2 counts is unacceptable from a "pro tuner". I would recommend getting the equipment needed to flash and learn to do it yourself. If I can do it, so can you or any1!!!
Old Sep 9, 2008 | 12:10 PM
TTP Engineering's Avatar
xs power exhuast manifold and dump pipe
k&n intake
underdrive pulley
greddy hard pipes
HKS bov
3 gauge apillor
dyno tune wideband
autometer narrowband
blitz turbo timer
LC-1 wide band o2 sencer
We don't remember ever seeing any knocksums out of the ordinary from any of our Milwaukee customers.
If we have tuned the car, send us a datalog. If not, then best of luck.
0-3 sums is about as much as we tolerate.
Furthermore, you might take a second look at your mod list if your car is not at its potential.
Old Sep 9, 2008 | 01:38 PM
C6C6CH3vo's Avatar
Knock cyl temps and pressures depend on the HP/liter. Stock evo's probably knock like mad from the factory
Old Sep 9, 2008 | 02:08 PM
I would assume it depends on exactly where you live, what fuel, and what ambient air temps, but here I have seen bonestock evo's that knock up to 10 counts and others that are absolutely quiet except they'll knock up top or down low but not both.
Old Sep 10, 2008 | 02:44 PM
just checked with a guy that tunes cars umm what would make my car once in boost cut octane levels to 0 but at idle and everythen else other then boost be 100
also throwing codes
P0137
P0403 EGR Solenoid. (different intake manifold egr deleted)
P0340 Crankshaft Position Sensor circuit.
P0335 Crankshaft Position Sensor circuit.
P0325 Knock Sensor 1 circuit.
