need help fast
Old Sep 10, 2008 | 07:36 PM
W2J's Avatar
W2J
need help fast
I bought some Greddy 720cc injectors based on the above seeing that alot of people here who used these setting worked right off the bat. Can somebody please help the car is idles at 10.4 afr on the wideband and goes to 10.0 when driving, I even went as far to reinstall the stock injectors and put back the stock values and that worked like before.
Old Sep 10, 2008 | 10:10 PM
tephra's Avatar
what did you fuel trims say?
Old Sep 11, 2008 | 12:34 AM
RazorLab's Avatar
What tephra said,
Every car is different, check the fuel trims and adjust accordingly.
Since you say it idles at 10.4, the low fuel trim would need to be maxed out positive and then some.
Old Sep 11, 2008 | 01:25 AM
h101171's Avatar
Originally Posted by razorlab
What tephra said,
Try to start with 660 and not with 636 - may be you were out of range
Old Sep 11, 2008 | 10:55 AM
W2J's Avatar
W2J
What tephra said,
I am a bit confused Idle should be find with the injector scaling, with all due respect your suggestion does not make any sense to me, if that was the case why does every evo has the exact scaling for 560cc injectors. can somebody please guide me to get this thing to work please. Also do I need to take the battery pole off after I reflash with new scaling? I was reading somewhere that they said that the trims will not reset with a flash unless this is done.
Old Sep 11, 2008 | 11:50 AM
RazorLab's Avatar
Idle is scaling and 14v latency.
Check your fuel trims, they should tell you what is going on.
Stock evos all use the same scaling and latency because they all come with the same parts, stock. The fuel trims are there to adjust for different climates, health of the car, etc.
Once you move away from stock, every evo is different.
Old Sep 11, 2008 | 11:57 AM
jmelocik's Avatar
Almost sounds like your front o2 sensor is bad. But you said putting the stockers and the stock setting back in it was fine right? Did you disconnect your battery for a bit to reset the trims before you started playing with the injector scaling and latencies.
Josh
Old Sep 11, 2008 | 12:51 PM
W2J's Avatar
W2J
Razorlab why is it that the stock scaling and latency for the STOCK INJECTORS don't matter what temp, climate and health of the car ect will idle good on any evo? you theory don't make sense.
Old Sep 11, 2008 | 12:59 PM
W2J's Avatar
W2J
Josh
thats the same question I asked ^ is it necessary?
Old Sep 11, 2008 | 01:29 PM
RazorLab's Avatar
It doesn't make sense to you because you keep ignoring the whole part about fuel trims.
It's not a theory, it's a fact.
You grabbed latencies and scaling from here on evom. Now you are wondering why your car is running like crap.
Here is the last advice I will give, please pay attention:
1. Check your fuel trims, anything more than +/- 5 should be delt with using latency and scaling adjustment
2. If your fuel trims are totally maxed out, I would lean more towards an injector or 02 issue (since you said your stock injectors didn't do this I would lean towards the new injectors)
3. You want to reset your fuel trims when adding new injectors. On 7-8 you have to cut power to the ECU in order to do this.
4. If all check out, I would triple check installation and/or if these injectors are really what you are being told they are.
5. Heaven forbid you have to do you own injector scaling since the free data from this site didn't work in your case.
again, CHECK YOUR FUEL TRIMS
Old Sep 11, 2008 | 04:19 PM
tephra's Avatar
woah, thats like a glitch in the matrix...
Old Sep 11, 2008 | 04:59 PM
W2J's Avatar
W2J
ROFL... take it down bro I think you have answered my question here
this is the only thing I did not do since I did not see it on the blackboard... thanks if all else fails I will make sure and let you know the findings.
jonmorera
Dec 14, 2015 03:29 PM
robbyredneck
May 26, 2015 07:05 PM
Mitsulover
For Sale - Cars For Sale
May 18, 2015 11:30 AM
Evo-ice
Jun 14, 2012 05:23 PM
tscompusa2
Aug 30, 2011 03:57 PM
