Evo 6.5 Help
Old Sep 17, 2008 | 01:24 PM
MarioTME's Avatar
Question Evo 6.5 Help
hey guys
i just wanted to ask if anyone have ever flashed a evo 6 ECU.
which cable supportsmy car? will the Tacrix 1.3 evo 8 cable do the thing?
please guys i need a reply ASAP :S
Old Sep 17, 2008 | 03:03 PM
kkarim's Avatar
You can't reflash the evo 6 ecu with ecuflash.
However, it's very easy to fit an evo 7 ecu in your car if you want, i think it's only a matter of switching a couple of wires around.
Old Sep 17, 2008 | 03:24 PM
joyce1bro's Avatar
^^ yup thats what i did
Old Sep 17, 2008 | 03:41 PM
MarioTME's Avatar
damn :S
more info on swaping a 6.5 ECU with a 7 ECU would be helpful guys..
any other options rather than changing ECU?
Old Sep 18, 2008 | 01:33 AM
Evo_Pma's Avatar
on the evo 6 u only can read the map from the ecu but cant write a new one?
Old Sep 18, 2008 | 01:59 AM
kkarim's Avatar
Here is a USDM evo8 ecu swap into a 6 TME.
https://www.evolutionm.net/forums/sh...d.php?t=356228
If you search a bit more, you will probably find the JDM/EUDM ecu swap for the EVO6 which i believe is easier to do.
Old Sep 18, 2008 | 02:02 AM
kkarim's Avatar
Evo 7 ECU in Evo 6 swap (found it online, do more research before applying):
Swap pins 32 and 34 around
connect pin 20 to 32
connect pin 21 to pin 34 (after they have been swapped over)
disconnect pin 87
Sounds easier than the USDM one...
Old Sep 18, 2008 | 03:40 PM
MarioTME's Avatar
no other options instead of taking off my ECU?
Old Sep 18, 2008 | 03:45 PM
kkarim's Avatar
I read somewhere that ECUTek has something for the Evo 6 ecu... Not really sure about that...
Old Sep 18, 2008 | 04:43 PM
cossie1's Avatar
Ecutek is the only option for reflashing a 5/6 ecu.
As above just fit an evo 7 ecu so you can use ecuflash.
In addition to the above wire swaps, you also need to move pin 6 to pin 53 if you want to keep the sas working.
Old Sep 19, 2008 | 03:10 AM
MarioTME's Avatar
whats the sas? :P
dont forget am a noobie here
no one here in my country has experianced swaping a 6 ECU with a 7 ECU :S
i dont wanna be the test lab
Old Sep 19, 2008 | 04:40 AM
cossie1's Avatar
SAS is secondary air system.
Basicly, it can be used to add in some mild pops and bangs, when you lift off the throttle.
Nothing very wild.
Old Sep 23, 2008 | 02:50 PM
MarioTME's Avatar
thanks man
i was curious how much can the original boost solenoid can handle?
Old Sep 23, 2008 | 04:12 PM
kkarim's Avatar
I use it for 22psi. It works great for me, although you have to use the appropriate restrictor, allthough i beleive you can take it as high as 25-26psi and still have decent accuracy.
Where are you from in the middle east?
Old Sep 23, 2008 | 05:14 PM
MarioTME's Avatar
thanks Karim.
well i live in Jordan but am originally lebanese
going to beirut on friday to have my ECUtek tuned hopefully
what about you?
devyn339
Jul 23, 2011 09:54 AM
Evokid03
For Sale - Miscellaneous Automotive
Jun 12, 2010 08:20 PM
NCarrillo
Dec 13, 2009 07:23 PM
EVO8YOU
Dec 15, 2008 04:39 PM
