how-to: control closed loop AFR with your wideband O2 system
Old Dec 3, 2009 | 04:22 PM
  #166
fostytou's Avatar
EvoM Community Team
Originally Posted by SyZyGy1394
I'm getting way too impatient. I may just wire my lc-1's narrowband sim to the front o2 for now until this comes out for V7.
Isn't 14.7 idle/cruise a little tooooo rich for e85? I know 14.7 on 93 is mainly for emissions and all and I'd like to lean it out for better mpg, but wouldn't the engine run better overall if it were leaner?
There are a few threads on this (and plenty of posts here)...
Pump gas runs better at 15.5 if you can control it tightly, though the cat won't be as hot.
E85 can run 16:1 (gasoline scale) no problem and some people run as lean as 17:1.
Old Dec 3, 2009 | 05:32 PM
  #167
SyZyGy1394's Avatar
You're not telling me anything new.
I'm mainly looking for what I have to do so it can work on v7...
Old Dec 7, 2009 | 10:09 AM
  #168
fostytou's Avatar
EvoM Community Team
Then why did you phrase it as a question?
If my wideband supported it, I'd probably rather change the analog lambda output simulator than modify ECU code.
Old Dec 8, 2009 | 10:38 AM
  #169
SyZyGy1394's Avatar
So I would imagine that If I just used my wbo2 to simulate the front nbo2 at lets say 16.0, then I'd imagine it would wreak havoc on my trims? Or could I just mess with the fuel map?
Sorry if its this semi-off topic cause its not dealing exactly with mrfred's patch.
Old Dec 25, 2009 | 09:52 PM
  #170
burnzy's Avatar
Originally Posted by Jack_of_Trades
Datalog both the USB WB readings and also datalog the analog input (purple wire) with an eval of "x" so we can compare the AFR readings to the bit values. Then we can dial it in.
Travman, you are correct that 0v= 9.6AFR and 5v=19.6AFR. With the ADC inout though, a bit value of 0=9.6AFR and 255=19.6AFR
EDIT:try this....
eval= (((5/255)*x)*2)+9.6
Its basically the same formula as the x/255*10+9.6 formula but written so you can see all of the work. You may need to fudge the values a bit to comprensate for voltage losses in the wiring and connections.
I tested both formulas and (x/255*10+9.6) seems to scale perfectly through the range, and it matches bang on, so I guess with a proper ground or non faulty zt2 the purple wire really is linear, with the other formula it's off by .2
Old Jan 26, 2010 | 02:10 PM
  #171
lan_evo_mr9's Avatar
Is this patch possible with V7 and the AEM UEGO?
Will the car's fuel trims actually respond with the same speed of a 6 wire (ie, better driveability)?
Old Jan 27, 2010 | 11:11 AM
  #172
fostytou's Avatar
EvoM Community Team
Yes, your trims will adjust to try to represent 16.0 as 1 lambda. If not, why would we even be talking about it?
Old Jan 27, 2010 | 11:22 AM
  #173
travman's Avatar
Yes it works with the V7 - I setup the patch to do some testing, i am back to the narrow band now but it did work.
Old Feb 2, 2010 | 10:20 AM
  #174
So my steps for implementing WB control would be this:
1. Wire analog WB signal to ECU pin x
2. I don not need to do rear sim patch becuase I'm running V7
3. Apply the patch in pg1 of this thread and copy all values from DL hex file to the new tables
using Fosty's calcs for the AEM.
Is there anything else that I'm missing and/or my steps wrong. Any info would be appreciated.
Matt
Old Feb 2, 2010 | 11:22 AM
  #175
mrfred's Avatar
Matt
I have yet to check whether tephra's v7 code space overlaps with my WB control patch space. If you see all 0xFFFF in the big patch tables, you're good to go, if you see anything else, don't do the patch.
Old Feb 2, 2010 | 11:32 AM
  #176
travman's Avatar
I checked before i applied the patch and everything seemed to be 0xFFFF .....I then applied that patch and all was well.
Stock Rom:
V7 Rom
Old Feb 2, 2010 | 02:58 PM
  #177
Awww crap, I changed a bunch of stuff from 0xffff to whatever. Which tables are supposed to be 0xffff and the others filled in with the DL hex file?
Old Feb 2, 2010 | 03:08 PM
  #178
OK, so let me get this straight....I leave the tables with the 0xffff alone and copy the values from the down loaded hex file into the other tables?
Old Feb 3, 2010 | 04:20 AM
  #179
travman's Avatar
No - copy everything over from the pre-patched rom.....
I am just showing the stock rom and V7 rom without the patch applied - doesn't seem V7 uses any space that the patch uses so it works fine.
Sorry for the confusion
Old Feb 3, 2010 | 11:55 AM
  #180
Ok, thanks....there are two rear O2 inputs for the ECU. Do I use the one for the heater input or the signal input? I'm assuming signal, which is pin 73.
I don't need to apply the rear o2 algorithm either since I'm using V7, correct? Just this patch?
