how-to: control closed loop AFR with your wideband O2 system
closed loop control
I finally got the patch to work. My aem gage sweeps a bit and reads my desired value. When I log in evoscan my afr says 19ish. I'm using fostytou's equation and 1/ml and bl/ml values. I'm not sure why my evo scan values are so far off. Any Ideas?
Hello
Is that fluctuation is normal with this patch at steady speed like 70mph ?
The video is in .mp4 . the fuel map set 15.7 .
http://rapidshare.com/files/406772261/100708_172546.mp4
quick question 1 is on and 0 is off? i have the xml in the base file i guess and it come up on every 9653 rom i have and i dont want it to interfere with the other cars . so i was wondering should i change it to 0 to make sure its off or leave it at 255.
Hello
Coud these patch causeing my stft and ltft low is 12.5% ?! The mid is 6.5% . All is after a long 3000miles trip. I think no because I would run lean afr like 15.6:1 and fuel trim + mean plus fuel how I know ?!
I will check boost leak maybe..
Hello,
If I dont have Front O2 sensor can I replace it with this patch and a WBO2 wired in the rear o2 ? I think yes maybe I will have front O2 heather CEL ?!
Can I tune new injectors with this patch turn on and wbo2 and without front o2 ? Will my fuel trims usefull too ?
Thank you ! Gergo
Thank you ! Gergo
someone ? Will this patch modify my stft fueltrims which will effect long time on the LTFT low and mid ?
other :
"If you prefer to use the the front O2 ADC input for something else, I have created a unique RAM address and MUT port to read whatever is attached to the front O2 sensor ADC input."
So If I wire an EGT sensor to the Front o2 pin I coud log it by Evoscan with the front o2 sensor MUT address ?
other :
Hello,
Thank you ! Gergo
Thank you ! Gergo
Depends what rom you have, but you should be able to... there are more posts about that topic in that thread and others.
other :
other :
