Map switching on evo IX
Old Sep 26, 2008 | 02:53 PM
xpro's Avatar
Hi,
i have nearly everything set up for my new patch,v5.10 but need some more info please.At the mo im still using the old patch v2
How do you actually switch maps on the go? and how do you know when map switching was successful?
is there any write up on this,before i do something stupid.
Thanks in advance! help apriciated
Old Sep 26, 2008 | 07:22 PM
tephra's Avatar
have u got an ICS switch?
if so then you just set map switching to autoics
then hold down autoics to switch maps... the green ICS light will start flashing slowly...
Old Sep 26, 2008 | 07:51 PM
tnt1106's Avatar
IX? dont think they have ICS switch? Or can you add one in?
Old Sep 26, 2008 | 08:04 PM
tephra's Avatar
mine does.
only USDM IX's (AFAIK) dont have ICS...
Old Sep 26, 2008 | 08:09 PM
tnt1106's Avatar
mine does.
all models have same wiring harness? ( could a usdm car just buy plug in switch?)
Old Sep 26, 2008 | 08:28 PM
tephra's Avatar
remove the plastic in between the seats and look
Old Sep 28, 2008 | 01:40 PM
Jeff_Jeske's Avatar
Anyone check on this?
Old Sep 28, 2008 | 06:26 PM
16vEVOIX's Avatar
I haven't seen a harness that had a plug for the ICS on my USDM IX
Old Sep 28, 2008 | 07:38 PM
RazorLab's Avatar
05+ USDM do not have the ICS wiring. However it does still have the plug behind the gauge cluster. That's about it.
Had a local 05 owner wire up the ICS icon to light up when he switched maps, just had to run the wire and buy a bulb to put in the cluster.
Old Sep 28, 2008 | 07:41 PM
tephra's Avatar
^ that's why I left the ICS flashing code in there for non-ICS evo's..
So they can wire in the bulb and it will flash
Old Sep 28, 2008 | 07:48 PM
RazorLab's Avatar
btw that bulb is bank from mitsu. I think he said it was $17 or something recockulious.
I don't think the ICS icon flashes. It's just solid when on alt map.
Old Sep 28, 2008 | 08:24 PM
tephra's Avatar
hrmm it should flash... either flash on or flash off, depending if its on/off to begin with..
Old Sep 29, 2008 | 12:38 PM
xpro's Avatar
tephra im nearly there now,ready to flash.Just one question when copying maps,for alternative map and main map,it says to leave only max wastegate duty 1,others dont matter anymore.In my case wastegate duty 1 its maxed out the 100.00 accross the range,while max wastegate duy 2,5,7 maps show different values.Will i just use the settings from wastegate duty 1 or copy values from w/gate duty 2 into map 1? rom im using is 8857008
Thanks a mill
Old Sep 29, 2008 | 06:27 PM
tephra's Avatar
88570008 is special, in that it has 2 BCS's
You need to use the updated XML so that you have MWGDC 1/1, 2/1, 3/1 and 1/2, 2/2 and 3/2
Then only 1/1 and 1/2 matter...
Old Oct 26, 2008 | 06:37 AM
joedr's Avatar
EvoM Moderator
Anyone have the part number for the bulb used on the ICS icon?
I can check when I go back home but.... Does anyone knows if the ICS icon is already on the IX cluster?
