GM BCS users: Are you using a 10 ohm resistor in series with BCS?
Old Sep 26, 2008 | 05:19 PM
mrfred's Avatar
GM boost control solenoid users: Are you using a 10 ohm resistor in series with the GM BCS to match the circuit resistance to the OEM BCS? If no, how long have you been running without a resistor?
Old Sep 26, 2008 | 05:40 PM
MR Turco's Avatar
I have the resistor installed.
Old Sep 26, 2008 | 06:34 PM
logic's Avatar
I've been using a 10ohm resistor since I installed the GM BCS originally. I suspect most folks running a GM BCS have wired it up per this thread's advice, so you may have some difficulty locating someone running it without.
Old Sep 26, 2008 | 06:45 PM
WRC-LVR's Avatar
Definitely with 10 ohm resistor.
Milburn
Old Sep 26, 2008 | 06:46 PM
tephra's Avatar
I used whatever resistor was spec'd in the thread
Old Sep 26, 2008 | 07:22 PM
Kracka's Avatar
I have a resistor. Its so cheap and easy, why risk it?
Old Sep 26, 2008 | 07:41 PM
mchuang's Avatar
I use to run a 10ohm resistor, when i had the GM solenoid hooked up. According to the subie guys using the resistor could cause some voltage drop slightly.
Old Sep 26, 2008 | 09:35 PM
cpoevo's Avatar
I run a 10 ohm 1 watt resistor
Old Sep 27, 2008 | 07:30 AM
fostytou's Avatar
EvoM Community Team
I'm running the AEM/MAC with a resistor.
The reason he is asking is because yes, it can cause voltage drop. This means that your 70hz might actually be something like 60hz with the solenoid not having enough power to fully switch sometimes at high speed/frequency.
Old Sep 27, 2008 | 11:47 AM
mchuang's Avatar
The Ingersol Rand is about 37ohms just for reference no resistor and cheap
Old Sep 27, 2008 | 04:32 PM
RazorLab's Avatar
we have a couple track cars running without for over a year with no issues.
Old Sep 27, 2008 | 05:22 PM
MR Turco's Avatar
So would it be better to run without the resistor?
Old Sep 27, 2008 | 05:41 PM
Jack_of_Trades's Avatar
What is the coil resistance of the GM BCS anyways? I tested my stock BCS and its 33 ohms. I would assume that the outut voltage on such a circuit would be regulated. I dont even know the maximum voltage of this output, anyone know?
Old Sep 27, 2008 | 07:07 PM
silver_evo's Avatar
I drop in voltage can not change frequency. How ever a drop in voltage will cause the solenoid to respond more slowly. Sorry this is off-topic, but that caught my eye. My own opinion is that you should run the correct voltage for the solenoid. A 10ohm resistor will not cause much of any voltage drop, but will reduce the current thru the solenoid, prolonging its life.
Old Sep 27, 2008 | 07:21 PM
Thats very true, in series it will have the same voltage across the solenoid and the resistor. The only reason to use the resistor would be to limit the current draw from the output circuit. At 12v (if thats what the circuit is) and the stock BCS being 33 ohms, thats 363 milliamps (0.363 amps). If the circuit is similar to a peak n hold design it would spike up to an amp while opening the solenoid but not much more IMO.
