Sudden drop of load during pull...
Old Sep 30, 2008 | 09:12 AM
  #31
Jack_of_Trades's Avatar
Yeah, 4th & 5th gear will always have higher boost than others so it seems to all make sense. Definitely invest in a JDM map sensor in the near future. As for the high load, if its not a boost leak (read TB's explanation above) then I'd surely say you are boosting higher than you are aware of in reality.
Old Sep 30, 2008 | 09:17 AM
  #32
TouringBubble's Avatar
I'm not sure of this ... I've heard and seen logs of both sides. Spikes may differ, but I think the consistent boost levels will be very similar in at least 3-6.
Old Sep 30, 2008 | 09:51 AM
  #33
RazorLab's Avatar
From what I have seen, most of the time, it's slightly higher boost to make the same load.
Old Sep 30, 2008 | 10:01 AM
  #34
Interesting ... I'll review my logs to see if I find the same things. From what I recall both boost and load are pretty consistent, but maybe I was looking at it from a 40k' level.
Old Nov 26, 2008 | 08:55 PM
  #35
kouzman's Avatar
bump!
The problem was the boost controller. I disconnected it and used a hallman mbc at 23-24psi... Max timing @ 12 degrees on redline, pumpgas and a racing weight of 3378 I ran 119-120 traps last Sunday with no traction whatsoever!
Posted full results at the drag racing forum...thanks for the feedback and the suggestions!
StreetThisEvo
Nov 24, 2015 05:11 AM
David Buschur
86
Oct 21, 2010 06:36 AM
Hiboost
Aug 11, 2009 10:06 AM
kouzman
May 18, 2007 03:42 PM
David Buschur
47
Sep 13, 2005 11:52 PM
