Solenoid: Bleed vs Interrupt
Old Nov 27, 2008 | 08:52 AM
Nurburgring's Avatar
I´ve searched and read a lot on the subject, but still can´t quite understand the differences between these 2 modes of operation. I´m installing a tactrix boost solenoid soon.
Could someone please help with this:
- Do you have to connect the hoses any different from what is shown in the attached diagram?
- Any tuning differences when doing the load or boost maps?
Thanks.
Attached Thumbnails Solenoid: Bleed vs Interrupt-prodrivebcs_3port-diagram.jpg
Old Nov 27, 2008 | 09:08 AM
jcsbanks's Avatar
The diagram looks sensible for a 3 port (interrupt) solenoid.
3 port solenoids (interrupt) need less duty and correction than 2 port (bleed) (unless you had wild restrictors on the 2 port) because when the solenoid is energised there should be no pressure going from the compressor outlet to the actuator. So you need no restrictors and have a wider control bandwidth.
Old Nov 27, 2008 | 09:30 AM
So, every 3 port solenoid works in interrupt mode when connected properly? Good to know thanks.
Old Nov 27, 2008 | 09:56 AM
mrfred's Avatar
I just finished up testing a stock solenoid and several 3-port solenoids.
https://www.evolutionm.net/forums/sh...d.php?t=379043
The graphs give a feel for the difference in pressure at the WGA between a stock bleed solenoid and a 3-port solenoid.
Old Nov 27, 2008 | 09:59 AM
jcsbanks's Avatar
Yes, it switches the wastegate actuator pressure source from compressor outlet to compressor inlet repeatedly with a square wave, the duty cycle setting the ratio between exclusively outlet (0%) and exclusively inlet (100%). In reality some ECUs, boost controllers or solenoids will not switch exclusively to inlet due to their pneumatic or electrical coil properties.
If you use 100% duty or exclusively inlet, then the turbo will build boost until the exhaust manifold pressure is sufficient to blow open the wastegate. This will likely bring the engine to full torque very quickly followed by full power which will hold in a straight line. You have a rally car style torque curve which makes for a very fast car - if you can control the direction of the car and your bottom end is not overwhelmed by the cylinder pressure from the massive torque.
Some great testing by mrfred there!
Old Nov 27, 2008 | 11:24 AM
Great. Thanks guys.
metallics2000
Oct 8, 2016 10:47 PM
4bangn
Aug 20, 2015 05:30 PM
wang4u
May 8, 2013 09:19 AM
sba
Apr 8, 2008 05:07 PM
EVOIX4me
Aug 23, 2006 08:56 AM
