table cuestion!
Old Sep 28, 2008 | 12:18 AM
shangai's Avatar
table cuestion!
im trying to read the tables, but its in load, i cant determine where the car runs, could i change it to psi? i know its a stupid question but i really want to know what means each load and the values approx on psi. also how the computer know when to change from high octane to low octane on the tables?
thanks for your help!
Old Sep 28, 2008 | 12:50 AM
magyar86's Avatar
you need to read the "how to tune a evo" thread, theres a lot of good info in it. to find out what load your car is hitting you have to log your wot pull (usually in 3rd gear).
Old Sep 28, 2008 | 02:16 PM
shangai's Avatar
with the evoscan? just bought it. listen how the compueter knows when to jump from one map to another (low octane. high octane)? thanks!
Old Sep 28, 2008 | 08:25 PM
EatSleepBoost's Avatar
your statements don't make sense. your vehicle is gonna be in the high octane map if you are WOT
Old Sep 28, 2008 | 09:24 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Octane number says the amount of interpolation of maps in question. I hope this answers your question.
Old Sep 28, 2008 | 09:25 PM
shangai's Avatar
So why is a low octane map with 255 load? it make sno sense?
Old Sep 29, 2008 | 12:53 AM
Mattjin's Avatar
I don't mean to be rude but if you cant figure this out you really shouldn't be trying to tune your car.
Old Sep 29, 2008 | 10:02 AM
shangai's Avatar
if i can tune haltech and other ecu? why i cant tune a simple oem ecu?
i just need to learn how does it work.. thats all.. and with your helpi know i can do it.. also i have a bachelor degree in ing. elec.. so lets brake the computer guys
Old Sep 29, 2008 | 07:05 PM
i am not positive on when and why your vehicle switches maps. from what i hear many people don't now that exact reason or when it switches maps.
from a theory i have read is that the low maps are basicly safety maps that your vehicle switches to when you are knocking. so basicly your low octane fuel map should be slightly richer than your high octane. Same for timing, make the low octane iginition map be more conservative and have less timing advance.
that is all i know and hopefully a guru will chime in.
Old Sep 29, 2008 | 07:19 PM
RazorLab's Avatar
The understanding is that the ECU will start to interpolate between the high and low octane map as soon as the "octane number" is decreased. If I recall correctly it takes 5-6 knock sum to start decreasing this number. I also believe it starts at 255 then decreases from there.
You will never run completely off the low octane map unless there is an error in the system. An example is if you disconnect the knock sensor. The system will report and error and it will run 100% off the low-octane map and also run 0% duty cycle on the boost system.
If the car is of full health and tuned correctly, you need not worry about the low-octane maps at all.
Old Sep 29, 2008 | 11:08 PM
shangai's Avatar
at these momment i have 0 counts o knock .. and almost 400hp. with stock evo 8 turbo, not green, not 20g, neither evo 9 turbo.. also no nos!! im hitting tomorrow the dyno again.. thanks for your help!! also is there is a formula to change from load to psi?
Old Sep 30, 2008 | 12:11 AM
tephra's Avatar
which tables do u want to change?
changing the scaling on the load based tables to PSI would just be wrong - load does not equate to PSI...
edit - 400hp? on racegas yeah?
Old Sep 30, 2008 | 02:40 AM
burgers22's Avatar
Very very roughly, below 100 load is vacuum, above 100 load is boost. But really you should keep the scale in load as it is more representative of what the ECU is seeing. If you do some logging with 2 byte load you'll see how the load changes during different driving situations.
Could be 400bhp at the flywheel.
MB
Old Sep 30, 2008 | 08:38 AM
shangai's Avatar
400awhp!!!! with mix of pump gas and c16.. but more pump than c16.. today im trying usin meth and pump gas.. lets see what happens!!!
Old Sep 30, 2008 | 11:36 AM
burgers22's Avatar
So 500 BHP at the fly...on a stock turbo.....how much boost are you running for that?
MB
