? Mivec Temp Trim Table ?
Old Sep 9, 2009 | 04:35 PM
mrfred's Avatar
Originally Posted by GrocMax
Of course it won't you just told the ECU the cam '0' point is 72 crank deg further advanced than it actually is.
I didn't just guess at what the tables does. I read the code, and its clearly an "upper bound" vs coolant temp. The ECU will clip any value read from the MIVEC table that is higher than this upper bound. If you want, I'll post the code for you to see yourself.
Old Sep 9, 2009 | 05:48 PM
JohnBradley's Avatar
The vs coolant temp could simply be a left over from the initial software write. Being vs coolant temp doesnt really amount to much in relation to what Groc is talking about. Its a pointer to the leading edge trigger (72* of crank rotation at the crank trigger to determine cam position relative to the crank) and is basically set at 72* as the 0 point (-1.2* advance on the MIVEC table, 0* BTDC according the factory service manual. The higher order standalones make this more apparent than the factory code does.
Old Sep 10, 2009 | 09:15 AM
03whitegsr's Avatar
Is the raw ECU value 255?
domyz
Sep 3, 2014 08:14 PM
curamrdan
E85 / Ethanol
Sep 24, 2013 08:08 AM
hkumar
11
Sep 9, 2013 07:55 PM
kozmic27
Nov 26, 2012 09:07 PM
realrift
Jan 15, 2011 12:15 PM
