Ralliart Thermostat = change temp scale?
Old Oct 26, 2009 | 02:14 AM
realrift's Avatar
Hi all,
I am thinking of adding a ralliart thermostat (opens at 71 degrees C).
Does the "Thermo Fan Duty" table need to be rescaled for temp?
Currently the Thermo Fan Duty table has temp from 84 - 107 degrees C. I have seen a post which shows the ralliart rom's Thermo Fan Duty and it starts at 70 degrees C
linky: https://www.evolutionm.net/forums/ec...ml#post6079712
What other settings in the rom need to be changed?
Eg: "Low Coolant Temp Timing Trim Map" table?
Thanks for any help/discussion,
Rift.
Old Oct 26, 2009 | 03:30 PM
todd6027's Avatar
i had one fitted didnt have to change the fan duty that was fine but idle would hang after a run . changed every idle table available at the time to no avail , refitted stock stat/stock idle settings all well again . i did see a water temp enrichment running table in some rom cant remember which one
Old Jan 14, 2011 | 09:26 AM
turboart's Avatar
sry to reveive this but i was wondering if you knew the stock thermostat temp for an 04 ralliart?
Old Jan 15, 2011 | 12:15 PM
todd6027's Avatar
not sure but prob 76.5deg C
Mattjin
Apr 8, 2024 05:34 PM
Raceghost
Aug 10, 2018 10:39 PM
PPM
Apr 2, 2015 09:35 AM
Drive02Lancer
Lancer Engine Tech
Jul 30, 2004 04:30 PM
ROB281
Lancer Engine Tech
May 5, 2003 06:41 PM
