what maximum side injetor can i use on stock ecu
Old Oct 5, 2008 | 08:26 PM
herwick evo's Avatar
curently mod;BR 30r with tubilar man,680 injector,BR FMIC,272 and 264 kelford,inj was max out at 28 psi on the dyno,so what would be a good ,safe side inj to use on stock ECU To get more boost than 28 psi.on race gas ...thanks you..
Old Oct 5, 2008 | 08:31 PM
SpoolnupTuning's Avatar
1200cc's, but if you use e95 you can go to 1600's with a good tuner!! 1600's will not work for 93 not unless you see a real good tuner!!
Old Oct 5, 2008 | 08:48 PM
u think Al at dynoflash could pull this off?
Old Oct 5, 2008 | 09:07 PM
1600's on 93?? IDK
Old Oct 5, 2008 | 10:06 PM
JohnBradley's Avatar
On that combo you dont need larger than 1200s and maybe eventually a second pump. I can tell you this talk of 1600s isnt so easy even on ethanol on a stock computer.
Old Oct 6, 2008 | 01:12 AM
RazorLab's Avatar
1200's should be ok on GT30R + E85
Race gas under 1k will be just fine.
Old Oct 6, 2008 | 04:29 AM
4TUN8's Avatar
OP didn't mention E-85..............
850cc injectors should be fine for a gt30r.
tscompusa
Jul 4, 2015 02:02 AM
tscompusa
Apr 28, 2012 01:20 PM
Boostfiend
Jan 11, 2011 09:39 AM
David Buschur
Oct 24, 2010 07:22 AM
spak920
61
Nov 20, 2006 10:52 AM
