Load Limit? - Anyone Ever See >380?
Old Oct 11, 2008 | 04:41 PM
Ted B's Avatar
Something appears to be pegged. I'm hitting exactly "380" load and staying at exactly that figure from 5200rpm until at least 7500 rpm. I never see anything greater than exactly "380", so that begs the question as to if there is some load limit in the factory ECU.
Anyone?
Old Oct 11, 2008 | 05:13 PM
kreionic's Avatar
Yes sir. Same deal i have pegged a few cars it stops at 379.6875
Old Oct 11, 2008 | 05:16 PM
Wicked E's Avatar
As far as I know, Mellon is >380 load on his new set-up.
-E
Old Oct 11, 2008 | 05:38 PM
Dapper Dan's Avatar
Im at 380 load on my current setup as well.
Old Oct 11, 2008 | 06:14 PM
Ted B's Avatar
That is not good. If this thing is capped at 380 load as it appears to be, this won't work.
Old Oct 11, 2008 | 06:18 PM
tephra's Avatar
How do you tune higher than ~380 load then?
Old Oct 11, 2008 | 06:33 PM
dan l's Avatar
On DSM's we had a thing called the injector cap. Basically I put a big turbo on one day, and compensated for my bigger injectors in the ecu, something that was not normally done years and years ago (people would AFC to fool the ecu). At any rate I would hit a cap where my injector pulsewidth wouldn't go any higher. Looking further it turned out to be a Load cap, wheras the ecu would just not accept a bigger number because it is irreverent, a stock car could NOT go this high so I guess mitsu decided to just cap it in case something went way haywire.
So basically some guys smarter than me found the section of code that capped the load and we NOP'd it out with 01 01 01 01 01 01 and wallah no more injector cap
Sounds like the evo ecu is doing the same thing. If anybody wants PM me or something and I can show you the code fix in the DSM ecu if that helps anybody.
EDIT:
I attached my notes that I saved for the IPW cap removal........
File Type: doc
CBRD
Dec 30, 2010 05:19 PM
Drifto
Feb 1, 2010 07:18 AM
house_of_senate
Jul 9, 2009 09:03 PM
Ceddy
Jun 16, 2009 12:37 PM
NIevo
Oct 12, 2006 09:30 PM
