"Logged Timing" deviating from Timing Map, every log, every time it does, it KNOCKS!!
Old Nov 4, 2008 | 01:26 PM
  #91
nonschlont's Avatar
Originally Posted by Jack_of_Trades
+1. If the GM 3 port is doing its job (which it is) why blame it? The tuner was just being conservative I think. Seems like you've dialed in yout timing again. AFR's seem fine for 91 IMO. I personally run the same AFR from peak boost to redline.
The GM BCS is doing its thing, not an issue! I was seeing full boost @ 3400-3500, and after Im still seeing the same spool up. But the tuner does not set up the WGDC the way I had it @ 100% till 2500... He had it at 77% till approx. 4500 guessing, dont quite remember. Im assuming this was to prevent overboost, but when I go about it (again) I will be setting it up w/ 100% till 2000 and taper it as needed.
I originally wanted to go "direct boost control" and was told no prob. but when I went down there, he doesnt do "direct boost control" another issue I had... I will be trying it out and see how that goes for me... I have the .xml set up, etc. Just need to do it! I kinda wanted to have a complete grasp on this method first...
Are you running 11.5 across? I was thinking of shooting for 11.5, but started off at 11.3 to see how knock prone it was @ 11.3. What is your take on leaning out as RPM goes up? I have read people trying this to compensate for taper. (a lil)
Believe it or not, but all I did to my Rom was make all the BDELS/MWGDC's maps the same, turn off leanspool, work out the BDELS to match my logs, since my load was off by atleast 10 points almost everywhere... Added the TBEC, leaned out spool up a bit, but still need to get it to 12.5 @ 3000 instead of 11.9, and leaned it out .2 throughout the map. to 11.3 I left the WGDC/Timing maps the same the same just to see if it would knock... When I go at it again, I will try to bring my timing where it should be...
am I right to think "Timing" should be linear, like this?
example: 3* @ 3000, 4* @ 3500, 5* @ 4000, 6* @ 4500, 7* @ 5000, 8* @ 5500, 9* @ 6000, 10* @ 6500, 11* @ 7000, 12* @ 7500? I think 11* is my magic # @ redline.
etay89
May 10, 2015 06:21 PM
rushi
Aug 11, 2014 09:47 AM
PL_MR
Aug 6, 2013 10:53 PM
Raceghost
Oct 10, 2011 04:34 PM
Raceghost
Sep 14, 2009 05:46 AM
