fed up with knock control
Old Oct 25, 2008 | 03:37 PM
  #91
Jack_of_Trades's Avatar
Originally Posted by dan l
Tephra,
If your looking for a wishlist to help people deal with 2.0L motors that cooperate, 2.0L motors that don't, and stroker motors that don't cooperate, here would be my wishlist.
1. Ignore timing pull up till a user defined moment knock threshold. It should still be able to be logged. IE: Ignore knock up to say 3 counts.
2. At the point where knock is over the threshold, allow a user defined variable to determine how much timing to pull. For instance say the knock threshold is 3 and we want to pull 1 degree of timing for every count. At 6 counts of knock this would pull 3 degrees of timing. If you were to enter a 0.5 in the variable for timing pull above threshold the ecu would pull 1.5 degree instead of 3.
3. You may also want to allow the user to edit the knock sum decay timer so that knock will bleed off faster. At engines make more power the stock knock decay becomes intrusive because it doesn't decay faster.
4. Ignore timing pull below a certain load range with a user defined variable. A 9:1 compression stock evo motor just really isn't going to ping and need timing pull on premium fuel in low load areas. 90% of the time this low load knock is not real. Even if it was it will not do any engine damage.
What all this will allow is for built motors to have an increased threshold before timing is pulled. My friends 2.3L stroker car for instance makes 3-4 counts of knock at full throttle no matter what boost or what timing we run. Thus we can increase the threshold as the background noise is higher than a bone stock 2.0L.
Having the ability to change the amount of timing being pull per count of knock allows you to vary the amount of protection you want to put on certain engine setups. Drag race cars for example can handle substantially more knock than a road race car.
Well thats my wishlist. Oh I'd also like a Startup Enrichment table to show up in the next version of your Tephra mods so that we can better account for switching from gas to E85 but that's slightly off topic.
That pretty much sounds like everyones wishlist to me This would be beyond awesome.
Old Oct 25, 2008 | 04:26 PM
  #92
dan l's Avatar
I should add that the current ROM development by Tephra, mrfred, and others is very good. I don't want to be greedy, but when asked for opinions, I'm going to give them.
Old Oct 25, 2008 | 05:28 PM
  #93
silver_evo's Avatar
That list sounds pretty darn good to me. My current setup always knocks ~3500rpm for 6-8 counts when < 120 load. Real annoying. I posted on this thread before about my symptoms.
Old Oct 26, 2008 | 01:14 PM
  #94
equinsu-ocha's Avatar
My 03 has been doing this since I bought it new. It was rare then. After a twin plate clutch it was so bad I wanted to drive the car into a river. It would happen 50% of the time on tip in under 3500 rpm and you could not cruise on the highway below 4k, the car would pull timing, then I'd modulate the throttle to fix it, cruise for 30 sec to a minute then it would do it again. I installed a new twin clutch, same thing. Then I switched to a single and haven't had it happen since, no pulled timing in a year now.
People have been trying to fix this problem since I bought my car, but no one has been able to. I'm gonna need a twin again soon for a built engine, but I get frustrated just thinking about having to buy an AEM just to keep my sanity.
Old Oct 26, 2008 | 02:02 PM
  #95
dan l's Avatar
I can attest that disabling knock below 100% load solves such issues. I have been doing it on my DSM for years.
Old Oct 26, 2008 | 04:18 PM
  #96
3geclipse's Avatar
im having the same problems!! always low load knock,im anxious waiting for this patch,being able to disable the knock sensor below certain load will be just AWSOME!!
Old Oct 26, 2008 | 04:26 PM
  #97
dan l's Avatar
I'll be honest, if you have a 2.0L motor and suffering phantom knock issues then you need to do a little tune up and check for noise/rattles. Your fix should not even need a patch.
For the stroker and some non balance shaft guys, man I really feel for ya.
Old Oct 26, 2008 | 04:45 PM
  #98
Knock counts during spoolup in the 2500-3000rpm range is very common on stock long block 2.0's with stock turbo's regardless of tuning so I wouldn't say its user error persay.
Old Oct 26, 2008 | 06:07 PM
  #99
tephra's Avatar
well my car likes to knock like a **** at 2500rpm 60-80 load...
there is a bit of road (new smooth road too) that it ALWAYS does it on...
Old Oct 26, 2008 | 07:04 PM
  #100
lan_evo_mr9's Avatar
Mine knocks all the time- idle, stationary rev, low boost, high boost. Just phantom though. Got a noisy lifter though.
Old Oct 26, 2008 | 07:57 PM
  #101
tephra's Avatar
Ok it's coded up - I havn't tested it outside the simulator yet, but it should be good to go.
I will send a test to razorlab first - if anyone else (that's good at testing) wants a go as well let me know with your ROMID (not pm, in this thread)
This is what it looks like:
It ONLY changes the knock for ignition timing pull (NOT OCTANENUMBER timing pull, and not fuel dump on knock..)
So basically if you say 50% then instead of 8 knocksum it will use 4 knocksum. You will still log 8 KS thou.
Old Oct 26, 2008 | 08:07 PM
  #102
Darwinn's Avatar
88840017 - will test it.
Old Oct 26, 2008 | 08:33 PM
  #103
tephra's Avatar
ok I have done up a 96530006 v5.12 ROM - don't ask about V5.11 its not integrated yet..
If anyone wants a copy just shoot me an email (tephra at gmail) and I will reply with the ROM. It *should* be fairly self-explanatory..
Old Oct 26, 2008 | 09:45 PM
  #104
3geclipse's Avatar
i will test it!! 94170008
Old Oct 26, 2008 | 10:02 PM
  #105
SeanV's Avatar
Awesome work
Gmail message sent.
