Ignition Retard Limit
Old Jan 14, 2018 | 04:00 AM
  #166
WytWun's Avatar
Originally Posted by Evo8life
sorry for reviving this thread but 96530706 cant seem to work i keep on getting error in ecuflash after adding these new tables and scaling
Without the error message(s) no one can begin to figure out what your problem is.
Old Jan 14, 2018 | 04:07 AM
  #167
Evo8life's Avatar
solved the error message went in ecuflash and changed the newly created table ignition reatrd limit to -20 i should just try it right now it should work
Old Jan 14, 2018 | 07:42 AM
  #168
Evo8life's Avatar
did everything and flashed the car but im not seeing less then -10 timing is there anything else then writing the tables and the scaling?
Old Jan 14, 2018 | 11:27 AM
  #169
todd6027's Avatar
did you put in these
<scaling name="TimingMUT" units="degrees" toexpr="x-20" frexpr="x+20" format="%.0f" min="-20" max="60" inc="1" storagetype="uint8" endian="big" />
<table name="Ignition Retard Limit" address="1813d" category="Timing" type="1D" level="2" scaling="TimingMUT" />
<table name="Ignition Advance Limit" address="1813f" category="Timing" type="1D" level="2" scaling="TimingMUT" />
Old Jan 14, 2018 | 11:35 AM
  #170
todd6027's Avatar
e mail me rom and xml il take a look
Old Jan 15, 2018 | 12:37 AM
  #171
Evo8life's Avatar
yeah i have put in these whats your email address ?
Old Jan 15, 2018 | 03:06 AM
  #172
Assault's Avatar
You've put both retard limits to -20?
Old Jan 15, 2018 | 06:40 AM
  #173
Evo8life's Avatar
what do you mean by both in ecuflash i have only set ignition retard limit to -20 and in my high oct ignition map i have put -20 is there something else i should do ?
Old Jan 15, 2018 | 06:52 AM
  #174
Evo8life's Avatar
email sent thanks for the help
Old Jan 18, 2018 | 03:37 AM
  #175
Evo8life's Avatar
what do you mean by both retard limits in xml file or in my rom in ecuflash?
Old Jan 19, 2018 | 12:51 PM
  #176
Assault's Avatar
If you've added the new retard limits as above your XML should now have at least two retard limits showing in ECUFlash and both need to be set to -20 deg, depending on the scaling. Setting up new maps in ECUFlash can sometimes be a little tricky and it sounds like you haven't got the retard limits defined correctly, but Todd will sort you out, he knows what he's doing.
Old Jan 19, 2018 | 01:55 PM
  #177
Evo8life's Avatar
yeah im in contact with him he sent my a file didnt have the time to try it yet tomorrow for sure
Old Jan 20, 2018 | 12:55 PM
  #178
ant_turbo's Avatar
I had something weird happen,, when I was messing with the launch maps
I adjusted both the retard limits and also added - timing to the the launch map
(nlts was on) So I was at the drag strip and 1-2 nlts was fine but as soon as got into 3rd gear the car fell on its face,,, no boost felt like if I went from 1st-like 5th gear,,,
Old Jan 21, 2018 | 03:53 AM
  #179
nikush's Avatar
it may be clutch button issue, i had same problem on a customer car.
Old Jan 25, 2018 | 09:04 PM
  #180
ant_turbo's Avatar
I don't believe its the switch .. because when I out the retard settings back to 203..
it didn't do it again..
