Boost Limit ECUFLASH
Old Nov 2, 2008 | 01:34 PM
ant_turbo's Avatar
What's Boost Limit in ecu flash? What's it do and how should you have it set??
I have a gt30r...THANKS,,,,
Old Nov 2, 2008 | 04:14 PM
RazorLab's Avatar
it's load
Old Nov 2, 2008 | 04:15 PM
Kracka's Avatar
I have mine set to 319 across the entire range which basically turns off boost cut. Anyone know if there is just a periphery bit to disable it instead?
Old Nov 2, 2008 | 10:05 PM
ant_turbo's Avatar
Ok so it is boost cut!! Well I was at the track the other day and running my c16 tune And I thought that I would remove my hks filter to get more air and in 3dr gear over 7000rpm it hit cut...
Should I leave them as is??? THANKS,,,,,,
3000-302
3500-302
4000-302
4500-302
5000-299
5500-294
6000-286
6500-281
7000-274
Old Nov 2, 2008 | 10:09 PM
RazorLab's Avatar
reference your 2byte load and adjust accordingly
Old Nov 2, 2008 | 10:28 PM
ant_turbo's Avatar
Thank You!!
Old Dec 14, 2008 | 09:45 PM
eitan's Avatar
Hmm. My Boost Limit table has 255 from 3000-5500, then slowly drops off. However, I've logged load in that range above 290 repeatedly without hitting boost cut. Is it as straightforward as it looks?
Old Dec 14, 2008 | 10:06 PM
tephra's Avatar
2byte load? or loadcalc?
it needs to exceed the 290 for 1000ms (or whatever u have in the timer value)
also 2byteload is higher OR lower than the load used by the boost limit routine (within 20 anyways)
Old Dec 14, 2008 | 10:08 PM
tephra's Avatar
tephra's Avatar
Old Dec 14, 2008 | 10:14 PM
RazorLab's Avatar
Tephra with the
COMBO PUNCH
Old Dec 14, 2008 | 10:18 PM
tephra's Avatar
lol man!
Old Dec 14, 2008 | 11:00 PM
eitan's Avatar
2-byte. I don't think it exceeded 1000ms, though. I mean, maybe. I'd have to find the log and check.
Old Dec 14, 2008 | 11:55 PM
tephra's Avatar
well it needs to exceed the load for the period of the timer.
otherwise it wont cut in.
Old Jan 3, 2009 | 12:44 PM
Creamo3's Avatar
What can be done if you are exceeding the 319 load and encountering boost cut? I just converted the car over to E85 (great stuff) and have been doing some 30+ psi tuning and encountering boost cut at around 5.5k rpms in 4th. Re-scale the MAF or just increase the timer?
Edit: It looks like I can just max out the timer to avoid this..... grrr I hate when the search function isn't working.
lodifreefly
Mitsubishi TC-SST Discussion
Dec 7, 2009 11:31 AM
GreedMOTO
18
Oct 29, 2006 12:10 PM
quad3d@work
May 11, 2005 11:32 AM
pkjing
Oct 28, 2004 06:56 AM
wheredafucrwe
Oct 26, 2004 12:10 AM
