EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Sep 29, 2011 | 06:13 AM
  #1726
evoscan's Avatar
Silver Sponsor
Originally Posted by And
I guess I could rearrange the items so the ones I want are at the top of the list so appear at the begining of the csv file
yes and with the new EvoSCan v2.9 coming soon, it is just a matter of "drag and drop" of the data items on the main screen of EvoScan to change the position of the items.. very handy.
Old Sep 29, 2011 | 06:34 AM
  #1727
And's Avatar
And
will it still be released in sept or will it now be oct?
Old Sep 29, 2011 | 08:52 PM
  #1728
SmurfZilla's Avatar
Hamish what are the chances of evoscan supporting the prosport widebands natively, if not natively is there any chance you might know the calculation's needed for evoscan to log accurately?
Old Sep 30, 2011 | 06:21 AM
  #1729
evoscan's Avatar
Silver Sponsor
I'm just adding a Dyno Correction dropdown box today. just have to test it out over the weekend and it should be all good to go.
Old Oct 1, 2011 | 11:35 AM
  #1730
SmurfZilla's Avatar
Just an update to my problem. My cable came today. Tried to get the GPS unit to see the ECU via evoscan....It connects so long as it has external power source.
ECUFlash still can't read the ECU. Its giving the same error message that I've researched on this forum as if the battery is too low. I started the car and then had it read and it still pukes after trying multiple times to read the ECU. Any ideas?
Old Oct 6, 2011 | 07:56 AM
  #1731
evoscan's Avatar
Silver Sponsor
Smurfzilla, how is your battery now? all charged and working? Don't forget to use 1.3U cable and the 12pin white connector hooked up for Evo9 read/reflashing on GPSnav, and the battery all charged, and the cables all connected, and it will work fine.
Old Oct 13, 2011 | 10:31 PM
  #1732
prowakeskater's Avatar
Originally Posted by Ceddy
Windows 7 and Vista have a feature called UAC.
The .xml in the Program Files directory is not actually used. Instead a copy of the program is made and placed in the Users directory, and that one is used.
If you try to edit or replace a .xml in the Program Files directory it will revert back to its original copy. This will drive you nuts if you don't know whats going on.
The solution is not to install EvoScan in the Program Files directory.
I install all my tuning programs, programs that might need their config files edited, and programs not fully compatible with Win7s UAC in another directory.
For example:
C:\ProgramsXP\
can someone please help me with this? Im getting an error when trying to change formulas in evoscan, and can't seem to find any solution.
I have already uninstalled and re-installed in various folders, including on the root of the C:\ drive. There doesn't seem to be any folders or files associated with evoscan in my User directory
this is a parallel running on a mac, windows 7
Old Oct 21, 2011 | 07:39 AM
  #1733
evoscan's Avatar
Silver Sponsor
I'm just preparing for EvoScan v2.9 release, can you guys send a PM to me with any sample csv logs. preferably with hp greater than 400hp+
thanks.
Old Oct 21, 2011 | 07:40 AM
  #1734
evoscan's Avatar
Silver Sponsor
If you have a Virtual Dyno full screenshot to go along with it, would be great also.
Old Oct 21, 2011 | 08:01 AM
  #1735
And's Avatar
And
how about these?
Attached Thumbnails EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review-and_logs.jpg
Old Oct 25, 2011 | 01:40 AM
  #1736
toeng's Avatar
Hi Hamish
Do not forget my problem about the GPS dont see OP2 driver? I wait you to fix it a year.
It used to see OP2 cable some time. Afer soft reboot, it do see driver again.
Old Oct 26, 2011 | 01:34 AM
  #1737
evoscan's Avatar
Silver Sponsor
Originally Posted by toeng
Hi Hamish
Do not forget my problem about the GPS dont see OP2 driver? I wait you to fix it a year. It used to see OP2 cable some time. Afer soft reboot, it do see driver again.
it works fine, there have been 4 new releases on the website. download and install the latest version from the gpsnav webpage on the evoscan website.
Old Oct 27, 2011 | 07:23 PM
  #1738
toeng's Avatar
Hi Hamish
I have used V2.2 bulid on GPS with problem. Wait to new version V2.3, it still have GPS can not see OP2 problem.
Less and Less time it can see OP2 and work fine that I do not know why!!!!!!!!!!!. But after I do not charge batt some time and use it again, It can not see OP2 again and so on.
It may be only my and individual problem, but I hope you help me more.
Thanks in advance
Old Oct 28, 2011 | 06:04 PM
  #1739
evoscan's Avatar
Silver Sponsor
I think you meant you used v2.3, yes v2.4 will be awesome for op2
Old Oct 29, 2011 | 02:16 PM
  #1740
itzwolf's Avatar
How's the release of EvoScan v2.9 coming?
Been looking forward to some of the new features...
