EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Sep 17, 2009 | 10:07 PM
  #1081
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by evo4mad
EvoScan v2.7 Beta4
Future Map Tracer suggestion improvements:
- Allow the map tracer to only display the selected range on the Line Graph.
- Allow support for Evo5 roms
If you wish to add to this improvements list, let me know.
What about adding some more actuators?
Old Sep 17, 2009 | 11:00 PM
  #1082
funks's Avatar
How about adding support for the PLX Wideband? PLX iMFD serial protocol info. Code that was listed below removed, I posted a newer version on page #74.
Old Sep 18, 2009 | 02:49 AM
  #1083
evo4mad's Avatar
I'll be adding read/clear dtc for EvoX, and fixing up OBDII logging and adding PLX support and also adding more Actuators support on the EvoScan GPS.
Old Sep 19, 2009 | 07:54 PM
  #1084
bandit09's Avatar
for anyone getting the map tracer to work with the evo x, could you please tell us what you did? I followed the tutorial on how to enable mode23 on the ECU and I did it, so I did a pull, opened the log, clicked map tracer, then right clicked at the bottom and selected my hex file (map thats on my car). Then I took my XML files from ecuflash folder and put those in the ROMS folder of evoscan and tried loading those too. No luck.
If anyone could help and tell me how to do it, that'd be great. Thanks!
Old Sep 19, 2009 | 08:39 PM
  #1085
xbox4414's Avatar
I got mine to work but just followed the instructions. So I'm not sure why it wouldn't work for you. Assuming you're running the latest Beta? As the first beta that was meant to have the Map Tracer working did not work at all...
Old Sep 20, 2009 | 12:39 AM
  #1086
bandit09's Avatar
yes i have the latest beta. What instructions are you referring to?
Old Sep 20, 2009 | 07:48 AM
  #1087
addo's Avatar
just ordered my GPS/EVO Scan..
i can't wait to receive will it be black or silver (hopefully black).
i already have a Tom Tom GPS account does that make a difference to any thing??
i placed a 3 day internal order so hopefully receive in the UK Mid week.
Old Sep 20, 2009 | 11:41 AM
  #1088
xbox4414's Avatar
Well not so much instructions but just following the text that is already on screen. Analyze - Map Tracer, then select the log, then right click to load hex file, and then just check on of the values u want to trace and it worked for me...
Old Sep 20, 2009 | 12:45 PM
  #1089
bandit09's Avatar
does your hex file have mode23 enabled?
Old Sep 20, 2009 | 12:50 PM
  #1090
xbox4414's Avatar
Yes it does.
Old Sep 20, 2009 | 01:18 PM
  #1091
bandit09's Avatar
so does mine.....there's gotta be something I'm doing wrong. I have Can 2006+ mitsu selected, mode23 USA EvoX selected, then I do a log. Then I open up map tracer, open my log, then right click at the bottom and select my .hex file that's on my car. the bottom half shows up, but the top half the cells stay white. No warning messages, no nothing. So I try selecting my ECU ID's xml file that i put in the ROMS folder in the Evoscan directory. Same thing, nothing happens.
I'm confused. If you or anyone could help, it would be MUCH appreciated
Old Sep 20, 2009 | 03:16 PM
  #1092
xbox4414's Avatar
The only thing I can think of is that although you added/downloaded the new exe file, maybe u didn't overwrite and/or it's opening an old exe file and you're not really using the latest beta. Only thing I can think of...
Old Sep 20, 2009 | 03:18 PM
  #1093
Mellon Racing's Avatar
I'm still getting the occasional and seemingly random BSOD when logging even if I don't touch a thing. Nobody else? I don't have a problem with 2.5
Old Sep 20, 2009 | 03:26 PM
  #1094
xbox4414's Avatar
Not when logging...but my desktop get those. And it just started getting these a few months ago...around 2.6 time...
Old Sep 20, 2009 | 03:27 PM
  #1095
I can have 2.6 open all day and not crash, it's only when I'm actively logging. I NEVER crash on any other application either.
