EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Sep 12, 2009 | 04:55 PM
  #1051
Excalibur's Avatar
Originally Posted by xbox4414
Okay so here is the thing you need the folder and files in the most forward window. Look at the location of the files in address bar. See I have the Zip open in the download folder and I have my EvoScan folder that is in the Program folder. The back window is the zip file. What you do is drag the single file from the zip and replace the EvoScan.exe file in forward window. You don't a folder like this? If you don't you didn't install the first EvoScan correctly.
Have all that and it's doing nothing. If you have a skype account I can show you.
Old Sep 12, 2009 | 05:10 PM
  #1052
Excalibur's Avatar
Followed everything. Got all the same popups and everything. Then, I go to open the once good file for evoscan and now I get an error.
Old Sep 12, 2009 | 07:38 PM
  #1053
SoCalRedLine's Avatar
Originally Posted by Jumperalex
Hey Hamish ... was that on the web page the whole time? I spent like an hour searching for that cable :O hahaha
Heh. I think we need another thread thats just for the gps logger. That way all the evoscan noobs can use this thread for questions about why vista is such a bad OS...lol
Old Sep 12, 2009 | 08:15 PM
  #1054
xbox4414's Avatar
Okay so has anyone tried Beta3? I did a pull today and it didn't log my AEM WB at all. All "0" in the values of the spread sheet. Not sure if it was just my end acting up or if it's EvoScan. I'll try a pull tomorrow.
-Ray
Old Sep 12, 2009 | 10:50 PM
  #1055
mfr122887's Avatar
Hamish,
I submitted a support ticket almost a month ago and have not received a response yet. Email is mfr122887@optonline.net
Old Sep 13, 2009 | 02:59 AM
  #1056
evo4mad's Avatar
Originally Posted by mfr122887
Hamish,
PM me your ticketid, or your full name, sorry my ticket system doesn't have an email search box.
Old Sep 13, 2009 | 11:12 AM
  #1057
XinNC's Avatar
Evo x gsr
- ECUFlash read/write ROMS from your ecu. Supports 2001-2007 Mitsubishi (for example Evo7/8/9/GS/GT/OZ)
Will this have support for the 08 Evo X GSR USM?
Thanks
Old Sep 13, 2009 | 02:32 PM
  #1058
GregM's Avatar
I'm trying to decide if I should buy the GPS Navigator or a laptop, because at the moment I have to borrow a laptop which isn't the best. With the GPS Navigator, it sounds like the Innovate LC1 is compatible and will connect and be logged by the GPS Navigator, is this correct?? If the GPS Navigator can't log from a wideband, then it sounds like the laptop is the best option. I'm totally new to all this, so hopefully my questions aren't too stupid.
Old Sep 13, 2009 | 03:25 PM
  #1059
nothere's Avatar
the gps will record the wideband, but you need a computer to "read" the log.
Old Sep 13, 2009 | 03:38 PM
  #1060
GregM's Avatar
Thanks, I'm thinking I may buy a netbook. About the same price as the GPS, but it can run alot more and can use any wideband instead of just the Innovate, plus run the standard pc version of Evoscan, and can even read the log files etc. Only thing a netbook doesn't have is the GPS, but then I'd hardly use that anyway where I live.
Old Sep 13, 2009 | 05:31 PM
  #1061
evo4mad's Avatar
I personally think that a GPS is the best option, unless you are a tuner, then a laptop is the best option.
This is what I do:
1) GPS will log wideband via usb to serial cable. See my website for one of those.
2) GPS will log to sd card, so you just take the sd card out when you get home and analyse it on the big screen. (even a laptop is not the best for this)
3) if your tuner wants you to send a log, just take the sdcard out of the gps and then email the log from the sdcard via your home pc.
4) if your tuner sends you a new hex rom file, just put the hex file back on your sd card, and then walk out to the car, and Flash it to your ecu using the GPS.
Couldn't be easier. (if you are your own tuner, then you may want a laptop, so that you can edit the values on the passenger seat with a laptop, but personally this is a PITA) I prefer to leave a tune in for at least a day before making any rash decisions about altering the fuel/timing/scalings. So a home PC map edit at the end of the day is fine for me.
In the future, versions of the Evoscan GPS will be things like map editing and live tuning.. these upgrades will be free softawre upgrades for all users... so support this effort by buying one now
Old Sep 13, 2009 | 05:34 PM
  #1062
evo4mad's Avatar
EvoScan v2.7 Beta4
Map Tracer Fixes in v2.7 Beta4
- Download Here
- Now loads xml files rommetadata from ecuflash without relying on an old ecuflash path registry key
- Now loads 2 or levels of xml includes. (which was the case with USDM EvoX xml rommetadata files.)
- Now added the CAN OBDII data.xml file
- Now realtime graphing stays in Sync when ticking more dataitems.
Future Map Tracer suggestion improvements:
- Allow the map tracer to only display the selected range on the Line Graph.
- Allow support for Evo5 roms
If you wish to add to this improvements list, let me know.
Old Sep 13, 2009 | 06:31 PM
  #1063
xbox4414's Avatar
Awesome. Map tracer seems to work. But curious when you are viewing the AFRMap log with the AFR table shouldn't they be the same?
As for suggestions...here are mine:
1) The ability to edit a map and save it in the Map Tracer. (For Evo X)
2) Add a AFR Calculator to the right column of the Map Tracer. Like I added in photoshop here:
http://img.photobucket.com/albums/v5...trace_idea.jpg
The AFR Calculator would use the following formula: NMAFR=DAFR X MAFR / AAFR
AAFR = The Actual AFR
MAFR = The fuel map AFR
DAFR = Desired AFR
NMAFR - New map AFR
Adding those would make it so much easier and faster to edit a ROM!
Also is there plans to add the ability to Read/Write to ECU for Evo X? Along with DTC's? I'm tired of using PCM every time to check and clear a DTC.
-Ray
Old Sep 13, 2009 | 06:43 PM
  #1064
golruss's Avatar
This is what I do:
What about the AEM wide band, when will it support it?
Old Sep 13, 2009 | 06:53 PM
  #1065
xbox4414's Avatar
I'm pretty sure it already supports the AEM WB. The AEM logs via USB to serial...he said if you need a cable check his site...
