EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Sorry, you xml data is invalid or out of date, send yours to evoscan.org and hamish will happily fix it for you. ??????????? Don't know what the **** it's talking about.
The file is not in the evoscan folder. opening it wherever it put it when I downloaded it. It didn't give me an option to put it anywhere. It went into a temporary internet file folder.
Ever since I downloaded v2.6 with the beta 2.7, I'm having problems opening logs in excel. I keep getting error messages and file location errors. Here's a screen shot of what I'm getting. I tried opening them directly from evoscan- no luck, I've tried copying and pasting to the saved datalog folder- no luck.
I'm converting to SD in the next week or so, so I need to have as many logs as possible to go over for a smooth conversion. Having them open in excel is obviously the most accurate way to view.
Then I might as well just have the laptop in the car all the time and not have bothered with the GPS/Logger. For me the point was to stop using my laptop all together and allow me to tune and tweak on a more continuous basis without having to PLAN to do it by lugging out the laptop and sitting it on my seat.
Oh and in case there was any confusion my comment about map editing is aimed at the EvoScanPPC on the GPS/Logger and not EvoScan for windows on a laptop.
I don't have an evoscan folder. I only have the files in a "downloaded" folder.
That's your problem. EvoScan is looking for files you don't have. The folder has all the data files it says are missing. You need to run a full install then. Did you buy a full version? There should have been a full installer file, and a folder created when you used the file it gives you after you buy the full version.
Would you like to just connect one cable from behind the dash to the EvoScan GPSNav?
Consider purchasing a mini usb extension cable from your local electronics store:
http://www.usbfirewire.com/uextendminib.html
Where is the v2.6b18 file or folder located? Because that wouldn't work either if you didn't have an EvoScan folder...
Okay so here is the thing you need the folder and files in the most forward window. Look at the location of the files in address bar. See I have the Zip open in the download folder and I have my EvoScan folder that is in the Program folder. The back window is the zip file. What you do is drag the single file from the zip and replace the EvoScan.exe file in forward window. You don't a folder like this? If you don't you didn't install the first EvoScan correctly.
no map editing
