COP alternative?
Old Nov 15, 2008 | 06:29 AM
honki24's Avatar
COP alternative?
I saw somewhere on here someone posted a thread where he found OE parts (coils etc) that would work with the stock ecu and was a budget COP setup. I've just looked for that thread for an hour. Do any of you recall seeing it and possibly have it bookmarked? I think he had part numbers and everything. Someone trying to help me out?
Old Nov 15, 2008 | 08:58 AM
oldevodude's Avatar
Yes I read that post also
I do know that some are using the Chrysler 300m coil. I believe I might have copied the other guy though that was using two GM coils with similar resistance to stock and mounting external coils and then using conventional wires. I will look although no guarantees
Old Nov 16, 2008 | 12:54 AM
cpoevo's Avatar
I believe this is the one you are talking about
https://www.evolutionm.net/forums/sh...ight=coil+plug
Old Nov 16, 2008 | 12:35 PM
Jack_of_Trades's Avatar
I read in turbo or d-sport magazine about a mirage with an evo drivetrain that was running the 300m coils just the other day. It definitely caught my attention when I browsed through the article.
Old Nov 16, 2008 | 12:37 PM
Johnboy1065's Avatar
couldnt you just use the HKS DLI 2???
Old Nov 16, 2008 | 12:38 PM
broddey's Avatar
DLI is an ignition amplifier, not a capacitor discharge unit. Big difference in spark.
Old Nov 17, 2008 | 05:30 AM
honki24's Avatar
Yep, that's the one. Thank you very much.
Old Nov 17, 2008 | 05:49 AM
jmelocik's Avatar
Actually the HKS DLi is both a CDI (at low RPM) and a transistor type ignition. Multiple sparks during low RPM high load situations and transistor type ignition amplification at High RPM.
Josh
Old Nov 17, 2008 | 05:52 AM
jmelocik's Avatar
Yes the HKS DLi can be rewired to control a COP system however it will still be a wasted spark system. Nothing wrong with that except the dwell time between the ignition cycles is effectively cut in half compared to a true individual fire COP system. Seems to work for a lot of people making big numbers though so who am I to fight what works and try to reinvent the wheel.
Josh
stiggysaurus
Nov 1, 2014 08:39 AM
mp72
May 5, 2011 06:05 AM
Chamama
13
Mar 28, 2010 07:14 AM
WannaRace
Midwest Region
14
Dec 2, 2003 09:11 AM
