IAT log you don't want to see
Old Nov 18, 2008 | 07:52 PM
nothere's Avatar
the entire log (for what its worth) is over on the Innovate.
it was the first session on a cool morning with two yellow laps and traffic.
jid2, just laying on the passengers footwell.
Old Nov 18, 2008 | 10:39 PM
RazorLab's Avatar
Originally Posted by nothere
I was working the afr in the 12.5 zone.
That seems a bit lean for hot lapping?
How does a piston disappear? I mean metal doesn't evaporate does it?
Old Nov 18, 2008 | 10:44 PM
Magnumpsi's Avatar
Originally Posted by GrocMax
preignition will not show up on your knock monitoring.
How do you figure this?
Mitch
Old Nov 18, 2008 | 11:11 PM
ExViTermini's Avatar
I'm guessing he hasn't taken the oil pan off yet When my engine let go all I found was half the rod and the wrist pin, piston was in a bunch of pieces.
Old Nov 19, 2008 | 04:51 AM
GrocMax's Avatar
Mitch
Because preignition is not an acoustically active event like end-gas detonation. There is no ping or knock just destruction.
Old Nov 19, 2008 | 06:00 AM
nothere's Avatar
[QUOTE=razorlab;6366748]That seems a bit lean for hot lapping?
I've come to that understanding now.
For several years I've been there or close without issues, this time I went leaner still when I didn't log after installing a test pipe.
English Racing replaced the motor, John Bradley has a picture or two, I think some of you have seen already.
I may of misunderstood, the piston wasn't there is what I got. It may very well be they meant the piston wasn't in the hole.
Old Nov 22, 2008 | 08:55 AM
nothere's Avatar
In a related note some people noted that the boost pressure was in the twenties when the throttle was at 50%.
How do people with aftermarket boost controllers limit early high boost pressures?
I have the boost hoses set up interrupt style, is that part of the issue?
Old Nov 22, 2008 | 09:33 AM
honki24's Avatar
Originally Posted by jid2
Where do you stash the computer?
I CADed a bracket up for mine that bolts to the the cross bars that are behind the rear seat. I think my solidworks file is on my other laptop.
spomi
Cobb AccessPORT
Oct 8, 2016 05:30 PM
villarrs
May 20, 2014 05:20 PM
drifterific
Aug 27, 2010 10:59 PM
Drew84
49
Dec 8, 2009 03:36 PM
